Wiper Delay Module............Which One Is The Best??
Old Nov 24, 2015 | 07:15 AM
toobroketoretire's Avatar
toobroketoretire
Default Wiper Delay Module............Which One Is The Best??
About 6 months ago I installed a "REVOLUTION" wiper delay module that provides an 8, 5, or 3 second delay. Rather than using a control **** to select the amount of delay it uses the stock switch. Move the switch lever to HIGH then back to LOW within 1 second and that gives the 8 second delay. Move the lever back to HIGH then LOW within 1 second and that changes it to the 5 second delay and same for the 3 second delay.
My question is which brand uses the little control **** that most of you have mounted to the left of the center vent? I have seen several of those installed but I didn't catch the brand name. Does that control **** give unlimited delay times or a certain number of them like 3 or 4? If it provides an unlimited amount of delay times I would be inclined to go that route.
