Wiring Through Firewall
Old Dec 3, 2015 | 04:52 PM
SwampeastMike's Avatar
SwampeastMike
Default Wiring Through Firewall
I'll soon be adding a combination auto dimming inside rear view mirror/compass/thermometer/garage door opener/map lights to my '79.
The only (and rather minor) difficulty I foresee is the sensor for the thermometer. It uses two small gauge wires. Every vehicle I've seen with such a sensor finds it front of the radiator where presumably it is in the best possible position to sense actual ambient air temperature.
Where would you suggest running the wires through the firewall? Is there any existing place that is reasonably easy to access, already has holes/grommet and has room for a little more wiring? I really want to avoid removing the entire dash if at all possible. I know how to do such (have removed mine more times than I care to say) but really don't want to do it again as my interior is completely assembled and perfectly fitted with everything working and amazingly few rattles/squeaks for a Corvette.
Old Dec 3, 2015 | 05:32 PM
toobroketoretire's Avatar
toobroketoretire
The grommets in the firewall will easily accept several more small gauge wires.
Old Dec 3, 2015 | 07:10 PM
Richard454's Avatar
Richard454
An old trick that I have used for many years- but haven't seen somebody else putting a Youtube out on it...yet...
I was routing some- OK a lot of extra wires- to the back of my car. Here's how I did it when I needed another hole on the grommet.
Just need-
- A piece of tubing slightly larger than the wire(s)
-Grinder
-Drill
Take one end of the pipe and sharpen up the edges on the grinder.
Chuck it up in your drill and carefully-slowly drill into the grommet- obviously being careful not to nick the other wires.
Remove pipe from the drill- run your wire(s) through the pipe and pull the pipe on through when you have the wire about as far as you need them.
Richard
DSCN4778 by richardhayes454, on Flickr
DSCN4777 by richardhayes454, on Flickr
DSCN4779 by richardhayes454, on Flickr
DSCN4781 by richardhayes454, on Flickr
Old Dec 3, 2015 | 09:31 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
on the drivers side firewall follow the speedo cable in, I have had no problem reaching wires from there by simply reaching up from under the dash
Old Dec 4, 2015 | 02:12 AM
Amorget's Avatar
Amorget
I am curious as to what mirror you bought that had all those features. Hard to find them with all that and the map lights.
Old Dec 4, 2015 | 07:02 AM
Richard454's Avatar
Richard454
When I was looking at them- looks like GM Truck was the ticket- only problem I found is that it would interfere w/ the sunvisors because of the width.
Old Dec 4, 2015 | 07:16 AM
SwampeastMike
Found it on ebay. It's a Gentex. Used and removed from some vehicle, cleaned up and with a new temp sensor/wiring. From what I read similar models were discontinued some time ago as were any that combine the Homelink garage opener and compass.
Thanks everyone for your suggestions!
Old Dec 4, 2015 | 10:40 AM
Amorget's Avatar
Amorget
I've never found a GM truck that had the compass, only the SUVs. The SUVs didn't have map lights, though because of the overhead console. I have a not so small pile of those.
Sounds like it might be the Genex 341 then. I was hoping for maybe another for common (and thus cheaper) source.
Old Dec 4, 2015 | 02:45 PM
Richard454's Avatar
Richard454
Sorry -I meant "****" Sport Luxury Utility Truck- -what I call my Avalanche!!!
It's been a while since I was looking- but the mirror were all going to require modification to the visors.
Couldn't find the dimensions on the Gentex 341-do you guys have them?
THANKS-
To Wiring Through Firewall
