Compression - Is 11:1 too much?
Old Dec 4, 2015 | 11:28 PM
454Luvr's Avatar
454Luvr
Originally Posted by jkippin
The key here is the aluminum heads. They will tolerate a full point of compression more than iron heads.
Is that due to the ability of aluminum to carry heat away from the combustion chamber faster? Or is it a mechanical design difference relative to older cast iron heads (quench area or something)?
Old Dec 4, 2015 | 11:49 PM
jkippin's Avatar
jkippin
Good question
Its because of the aluminium's ability to dissipate the heat better. So in order to get an aluminium head to run efficiently you actually need to raise the compression ratio to build the heat. All this though is moot if you cant flow enough air through the runners which is important to sustain the VE of the engine. also most aluminium heads have more core shifting in them over iron heads. Which is again important to buy a quality casting.
So much more to this than just buying a bunch of brand name performance parts and putting something together expecting to make over 350 .fwhp.
I've seen many people buy the latest and greatest parts expecting to have a street slayer only to have a slug.
Old Dec 4, 2015 | 11:59 PM
htown81vette's Avatar
htown81vette
I agree 100%. Same is true for exhaust too. Put a pair of zoomies on a stock engine it will run like crap.
Old Dec 5, 2015 | 12:04 AM
pauldana's Avatar
pauldana
Ran my 350... then 383 for years on 10.5:1 with iron Sportsman II ported and polished heads.. 91 pump, never a problem,,,
Old Dec 6, 2015 | 11:40 AM
diehrd's Avatar
diehrd
Originally Posted by toobroketoretire
Modern engines with reverse flow cooling systems can tolerate higher cylinder pressures because the heads get cooled first. But for our aging C3's I feel its best to limit the compression ratios to around 10 to 10.5 to 1 to avoid detonation. I'm running a 9.95 to 1 compression ratio in my 454" powered '71 and I can barely get by with 91 octane and 31 degrees of advance.
I can remember compression ratios as high as 13.5 to 1 in the late 60's muscle cars but that was when 102 octane gasoline was available but even then an octane booster was added for racing. Many folks used 115 octane aviation gasoline which was about 5 times the cost.
Do you post just to be opposite ?? I really wonder how you come up with the things you say and just sit back and think it can only be possible if you are trying to be opposite or create a defenseless position so you can argue with others.
Old Dec 6, 2015 | 07:12 PM
454Luvr's Avatar
454Luvr
So only people who agree with the majority can post? His experience in this case matches up with mine. Now maybe it's not 100% applicable being as this discussion seems to center on small blocks and aluminum heads. However, he was pretty careful to define the conditions. Does he really need to be reprimanded for that?
Old Dec 6, 2015 | 07:23 PM
keithinspace's Avatar
keithinspace
Another high-compression engine here.
350 with aluminum heads. High duration cam.
10.5:1 compression.
I run 93 octane and have been happy as a clam.
Occasionally, I'll be forced to put a 'lesser' 92 octane fuel in...Citgo/Wawa/Sheetz...I prefer to purchase from BP/Sunoco/Exxon/Shell and the like. I keep a bottle of Octane Booster handy and put in a half bottle just to make sure I'm good. I feel comfortable that I would be OK, but it's cheap insurance. I'd prefer keep this engine around for a while.
11.0:1 would be closer to the edge, but probably not over the limit with the right things done to the engine.
Old Dec 6, 2015 | 07:56 PM
jkippin's Avatar
jkippin
The original question was is 11:1 compression too much. Many people here are running 11:1 or close in both big and small blocks with good results on pump fuel.
I am doing it with both BBC and SBC. Big deal for me right? The only point I'm trying to say is IT can be done I'm doing it and I'm not really smarter than everyone else. Its just careful consideration of parts and using todays better head designs that are superior in flow and design than earlier heads.
Old Dec 6, 2015 | 08:04 PM
diehrd's Avatar
diehrd
Nope , lots of people go into a topic and post about themselves NOT about what the OP is asking. Or go off on tangents that also have no useful information to the specific question.
Old Dec 6, 2015 | 08:36 PM
htown81vette
Seems that toobroke's post was relevant to the question being asked. I also happen to agree with it his opinion. The OP was asking for opinions. He got them. Not all opinions are going to be exactly the same as our individual experiences are going to vary. I also notice you seem to be trolling everywhere he posts. I'm personally tired of seeing you troll toobroke for no apparent reason other than you just don't have anything else better to do.
Old Dec 6, 2015 | 08:47 PM
htown81vette
I understand where you are coming from. It CAN be done. I think the old 10.5:1 rule of thumb is conservative. Not everyone has the skillset/knowledge to properly choose the correct cam, etc. So it's better to err on the conservative. Getting too greedy with compression, along with mismatched components, can cost alot of money, as in a blown engine. And all for .5 pt increase in compression that probably won't amount to much power at all. Not worth it. Unless you really know what you are doing. My LS engine builder says that's the number 1 reason why he gets other peoples blown engines because they get "greedy" with their tuning, compression, etc.
Old Dec 7, 2015 | 08:36 AM
diehrd's Avatar
diehrd
Cute , you call what you just did what ?
And this in not about individual experiences it is a specific question being asked , no one needs to tell a story about there cast headed BB LMAO or there engine builders dumb statements
OP 11.1 on street gas is not only doable but done easily and often.
Old Dec 7, 2015 | 09:21 AM
  #33
SH-60B's Avatar
SH-60B
You're kidding, right? 10 posts in this thread are about individual experiences, lol! I'm at 9.75 : 1 with iron heads, 91 octane minimum. I know the same combination will take a point higher with aluminum heads.
Old Dec 7, 2015 | 10:44 AM
  #34
pauldana's Avatar
pauldana
You feed the troll,,,,, This is where you went wrong:total:
And a junior member, whom is void of the trolls doings,,, well,,, you know:-)
peace brother don't feed the troll...
Old Dec 7, 2015 | 01:25 PM
  #35
454Luvr's Avatar
454Luvr
OP's first post: "Is anyone doing this?" You read that, right? Seems to me, individual experiences are exactly what he's asking for. I get that you think the responses aren't sufficiently relevant, but that's a judgement call. No reason to tell someone to shut up. Damn, I was hoping Vette forums wouldn't have so much of this egocentric crap.
Old Dec 7, 2015 | 01:35 PM
  #36
htown81vette
Trolling is when you constantly follow someone and post everywhere they post. I just did it once. Did I call anyone names? Did I make any untrue accusations or untrue statements? NOPE. Therefore, not trolling...
Where in the rules of this forum does it say we can't talk about our own individual experiences? I do it all the time. Is this **** Germany? Do we need to relocate to exercise our First Amendment Rights?
Yeah I know, I have 11.3:1 in my 10 sec Firebird (street car), and I run on 93 octane and have well over 100 passes on the motor.
Old Dec 7, 2015 | 04:13 PM
  #37
diehrd's Avatar
diehrd
If any relevant member of this forum thinks I follow any member around please post up.
And you other 2 are still crying because I pointed out your useless posts in a different thread that completely changed a topic on the OP .. LMAO get over it .
OP 11.1 is fine ,, No need to ask "My engine builder" and then post I have a 10 second firebird .. LMFAO ..
To Compression - Is 11:1 too much?
Old Dec 7, 2015 | 08:56 PM
  #38
htown81vette
Speaking of irrelevant....anyone who has an SHP 427 and only runs 11's....or dreams to one day...that is truly sad. You do know that, at this day and age there are LS engines with mere bolt ons running those times don't you? I thought my car was slow...
If I had that 427 SBC it would be running 9's thats a fact.
Old Dec 7, 2015 | 09:00 PM
  #39
htown81vette
And further, if you say 11:1 is fine without knowing the angle ABDC in which the intake valve closes (from the cam card), you are making a very dangerous blanket statement that could result is someone destroying their engine. OR you want everyone to be as slow as you? Ahhhhh....I get it now....
Old Dec 7, 2015 | 09:50 PM
  #40
diehrd's Avatar
diehrd
Who is trolling who ? You sound like one of a few guys from Digital corvette forum ... And I think you have been banned for your posts once maybe its time it happens again ?
