Intellitronix gauges
Old Dec 5, 2015 | 05:15 PM
Kacyc3's Avatar
Kacyc3
Default Intellitronix gauges
Is anyone still on here using the kit for the C3?
Old Dec 5, 2015 | 10:45 PM
RockyL32's Avatar
RockyL32
From: If your not the lead dog the view never changes Boise, Id
I had an older set, one of the originals from when they where 2001 Technologies. I had a problem with them and they asked to keep my old set and sent me a brand new kit. I just finished installing them and really like them. The speedometer has a 0 to 60 timer 1/4 mile time as well as high speed recall. Just need to get used to the fuel gauge reading in percentage of fuel ( reads 100 when full 75 when 3/4 etc.) if you like the look of a digital gauge they are great.
Old Dec 5, 2015 | 10:54 PM
Kacyc3's Avatar
Kacyc3
do you have pics of how you did the install? i have a new kit and the instructions are non existent for the center gauges.
Old Dec 5, 2015 | 10:57 PM
RockyL32's Avatar
RockyL32
Old Dec 5, 2015 | 11:01 PM
RockyL32's Avatar
RockyL32
During install
Old Dec 5, 2015 | 11:02 PM
RockyL32's Avatar
RockyL32
I don't have pictures during the install. Are you having trouble wiring or mounting the center console
Old Dec 5, 2015 | 11:04 PM
Kacyc3's Avatar
Kacyc3
how do they mount in the bezel, what pieces did you reuse?
Old Dec 5, 2015 | 11:07 PM
Kacyc3's Avatar
Kacyc3
mounting, I have to trim the circuit board, black acrylic and the speedo needs to be recessed to make fitment better.
Old Dec 5, 2015 | 11:11 PM
RockyL32's Avatar
RockyL32
I reused the blue metal housing and the clear lens. With the center face down on the table I put in the clear lense, the smoked lense, the gauge board then the blue metal housing held in by the screws that held in the original gauge cluster. Carefull not to over tighten the screws you don't want to break the plastic screw towers.
Old Dec 5, 2015 | 11:46 PM
Kacyc3's Avatar
Kacyc3
Did you reuse the metal front piece also?
Old Dec 6, 2015 | 12:17 AM
RockyL32's Avatar
RockyL32
Sorry you are right that blue tray is up front it went clear lense, blue metal frame, smoked lens, then the gauge circuit board. The kit comes with an assortment of plastic tabs and spacers to set the speedo and tach in the bezel, I used the tabs that came with the old set, I liked them better and they were all ready properly spaced for my Bezel. I also put the speedometer sending unit on the transducer where the short cable to the speedo came from instead of the transmission. The speedo works great and I retained my cruise controle.
Old Dec 6, 2015 | 12:39 AM
Kacyc3's Avatar
Kacyc3
My cruise has been removed and not sure i could reinstall it, my speedo dropped in with no tabs. The black acrylic won't fit inside the front metal housing. Might try to put the cruise back on with my efi.
Old Jun 25, 2016 | 11:21 PM
Kacyc3's Avatar
Kacyc3
Where did you put the momentary switch to selection option for the speedo?
Old Jun 27, 2016 | 12:39 AM
RockyL32's Avatar
RockyL32
I put that switch on the small panel under the steering wheel.
To Intellitronix gauges
