The tubes that go into the manifold that inject those gases cause a restriction in the flow taking them out will also add a little bit more horse power because a better flow
These were left in my 78 when the PO removed all the extra stuff on the outside:
It does dilute the exhaust which is what it really accomplished, it isn't vital to the cars operation and I'd pull it off and at least save some weight.
But I agree box it up and keep it one day it may be worth something
The whole idea for headers is free flowing exhaust... Anything that hampers those exhaust gasses from flowing will affect horse power adversely... How much? That is up for debate:-).
You get your torque manly for CI and compression... Horse power comes from rpm... Thus the formula for hp is (tq X rpm/)5252
The 79 has a 3.55 rear gear ratio so it will seem peppy compared to the typical 3.08 or the anemic 2.79 or whatever it was in the early 80 cars. The L82 has decent compression, decent intake and carb and a decent cam. Downfall is the exhaust but the 2 1/2 true duel with no cat will really help. I would hook the air pump belt up. The exhaust manifolds have a lot of backpressure and the exhaust will be forced back into the pump, likely trashing it. The A.I.R components on the early 70's cars are quite valuable as the L48 cars did not have them but the performance engines did. The states that require smog you need that pump so it has value because a LOT of them were removed and thrown away. Keep it as it was. Only cost a couple HP if that.
Thanks all for the correction of my poor memory of the earliest "smog" controls with completely mechanical carburetors!
I had forgotten that there is so much unburned fuel in the exhaust that injecting fresh air directly into the exhaust manifold would result in most of it being fully combusted with reduced CO.
As I do believe in being reasonably considerate regarding pollution I will reinstall the belt on the A.I.R. pump as it is performing a useful service and I can deal with the small amount of lost engine power.
