Hood help?
Old Dec 13, 2015 | 03:54 PM
Cattiva73's Avatar
Cattiva73
Default Hood help?
Hallo, its been a long time and while I've been rebuilding the engine on my 1973 BB I came to a complete stop/dilemma!..:
After putting a bigger/taller intake I can't close the Hood! I tried everything and the clearance between the carb and hood with No filter is only 1/2 inch!!
I dont like to cut a hole on the hood!.so
- should I have the body shop rise the original BB hood
or should I get one of those High Rise Twin Turbo Hood form Corvette America...I like them but do the have more clearance than my BB one??
here's the link:
http://www.corvetteamerica.com/cf/di...word%3A%20hood
Cheers
Old Dec 13, 2015 | 04:10 PM
toobroketoretire's Avatar
toobroketoretire
here's the link:
Cheers
You'll need an L-88 style hood and even then you may have to make modifications to it.
Old Dec 13, 2015 | 04:51 PM
Cattiva73's Avatar
Cattiva73
I thought about that and yes you,re right I would still need modif.!
Should I just have body shop rise my hood scoop then?..don't even
know how expensive its going to be
Old Dec 13, 2015 | 05:06 PM
Kacyc3's Avatar
Kacyc3
http://www.ecklerscorvette.com/corve...1973-1976.html
Old Dec 13, 2015 | 05:11 PM
toobroketoretire
You'd be a lot better off buying an L-88 style hood and then have a body shop make any additional modifications to it. I am running a heavily modified drop base air cleaner with a 3" tall element and even then I had to remove 1/4" from the top of my Air Gap intake manifold to end up with a whopping 1/8" clearance.
Old Dec 13, 2015 | 05:36 PM
Kacyc3's Avatar
Kacyc3
If you follow that link I posted above that is the high rise version of the L88 hood that is 1.5 in taller than the original. Another option is a tall cowl induction hood.
Old Dec 13, 2015 | 05:41 PM
hugie82's Avatar
hugie82
Machine shop can machine your carb flange down or you can try those form triangle air cleaners that like to catch fire. This is a well known problem, why did you use that intake?
Old Dec 13, 2015 | 05:46 PM
toobroketoretire
I assumed it would fit under my aftermarket L-88 hood but quickly found I needed to cut my air cleaner base down about 5/8", heavily dimple it to clear the Holley float adjustment screws, AND cut 1/4" off the top of my intake manifold. I just did what I needed to do to make everything work.
Old Dec 13, 2015 | 06:43 PM
Cattiva73's Avatar
Cattiva73
Thanks..are you talking about this one?:
Part #: 25-314580-1
http://www.ecklerscorvette.com/hood-...-and-high.html
Old Dec 13, 2015 | 06:47 PM
Cattiva73's Avatar
Cattiva73
You're too funny...I guess Im NOT gonna try those then.
the rise from my BB hood its only 2"..any upgraded intake would have give me trouble!..I thought I could resolve with a drop base filter...but NO such luck
Old Dec 13, 2015 | 06:55 PM
Kacyc3's Avatar
Kacyc3
neither of our links worked... but it looks like this.
Old Dec 13, 2015 | 07:35 PM
Cattiva73's Avatar
Cattiva73
Thanks..do you know how tall is it?..4" ?
Old Dec 13, 2015 | 07:41 PM
Kacyc3's Avatar
Kacyc3
it does say it is 4in tall.
Old Dec 13, 2015 | 07:50 PM
Cattiva73's Avatar
Cattiva73
well...my BB hood has a 2" rise..so this one would only gain me 2" more..not enough imo since the tip of the carb. is less than 1/2 inch from touching!
the only other option it would be a 4" scoop on top of my hood...
thoughts?
Old Dec 13, 2015 | 08:52 PM
Kacyc3's Avatar
Kacyc3
thoughts?
a drop base air cleaner and this hood
http://www.ebay.com/itm/1973-1982-Co...VWAFl2&vxp=mtr
Old Dec 14, 2015 | 10:13 AM
Cattiva73's Avatar
Cattiva73
u think this is my only option ???
Old Dec 14, 2015 | 11:16 AM
Kacyc3's Avatar
Kacyc3
That is the only hood I know of that tall, pm tek trans and ask him about his I know he has a hood similar to this one.
If nothing else works buy a cheap stock hood and hack it up, don't do it to your OEM bb hood.
To Hood help?
Old Dec 14, 2015 | 02:50 PM
Cattiva73's Avatar
Cattiva73
..Anyone can tell me how tall is the OEM hood on a 1973 corvette Big Block?
Old Dec 14, 2015 | 02:55 PM
Kacyc3's Avatar
Kacyc3
have a look at this and maybe ask post 4 what he has
https://www.corvetteforum.com/forums...ine-build.html
Old Dec 14, 2015 | 05:14 PM
Cattiva73's Avatar
Cattiva73
tried to measure it and Im thinking 2" ...? anyone?
