1973 Corvette, Engine not firing
Old Dec 13, 2015 | 11:32 PM
sumter's Avatar
sumter
7th Gear
Default 1973 Corvette, Engine not firing
Hello to all.
this is my first post on the forum.
I have a 1973 fully stock Corvette. It has suddenly stopped starting after a couple of weeks of not being driven. The car turns over fine and everything seems to be working only the car isn't starting. After determining the engine is getting air and fuel, the spark became the next issue. I have replaced the points, condenser, rotor button and distributor cap without success. I then replaced the original ignition coil thinking the 40+ year old coil finally wore out. The car is still not starting. I am using an after market Flame-Thrower 1.5 ohm 40000 with an internal resistor coil. Still not sure if the car is getting any spark. Before all this happened, the car was running rough and the secondaries were not opening. This was the reason for replacing the ignition coil. Is there anything else I need to check or replace? Pretty sure the point gap is correct and spark plugs look good.
I really need some help on this as I am out of ideas.
Old Dec 14, 2015 | 04:02 AM
toobroketoretire's Avatar
toobroketoretire
Originally Posted by sumter
Hello to all.
Welcome to our forum. The Pertronix Flame Thrower coils need 12 volts going to them; not the factory braided resistance wire that only produces 6 volts. Most people run a 12 gauge wire from the fuse block's IGN terminal to the + side of the coil.
Check the spark take the coil wire off and hold it next to a ground then have someone crank it. It should produce a fat blue spark at least 1/2" long. If it doesn't you have an issue somewhere in your ignition system.
You'll never see your secondaries open in your driveway as it takes a huge volume of air to open them. And the Quadrajets have a secondary "lockout" that prevents the secondaries from opening until the choke butterfly is fully open.
Check for a spark then get back to us.
Old Dec 14, 2015 | 10:58 AM
MelWff's Avatar
MelWff
do you have a dwell meter to check that the points are set for 30 degrees of dwell?
Old Dec 14, 2015 | 08:06 PM
USA-OSC's Avatar
USA-OSC
I just went through this. I thought the points were set at .016, but they were not. After manually manipulating the points open and closed several times I reset them again at .016 and it fired right up. My points were used so the .016, yours being new you will want to set at .019. Good luck.
Old Dec 14, 2015 | 11:10 PM
GRipp 73's Avatar
GRipp 73
Sounds like you are at least willing to do the wrenching yourself! Great. Sometimes it helps to have a second set of hands and eyes on a problem to see what is going on. Where are you located? You might have another forum member that is nearby and might be able to help diagnose the problem. But the advice you have gotten thus far is sound.
Good Luck!
Old Dec 14, 2015 | 11:22 PM
sumter's Avatar
sumter
7th Gear
Good Luck!
I am near Birmingham, Alabama
Old Dec 14, 2015 | 11:26 PM
sumter's Avatar
sumter
7th Gear
I'll check for the spark. Thanks for the advice.
Old Dec 14, 2015 | 11:28 PM
sumter's Avatar
sumter
7th Gear
Do not have a dwell meter but know someone who does. will definitely give this a try. Thank you.
Old Dec 14, 2015 | 11:30 PM
sumter's Avatar
sumter
7th Gear
I thought I had set them at the .019. Maybe I had them at .016 instead. will give this a try and see what happens.
Old Dec 15, 2015 | 03:07 AM
toobroketoretire
As the specs call for a dwell of 28 to 32 the point gap isn't critical at all because it should easily fire at any gap from .010" to .030". New points require about .019" so set them at .019" and check for a spark from the coil wire when held near a ground.
Old Dec 15, 2015 | 05:06 PM
goatherder's Avatar
goatherder
1st Gear
also make sure the distributor rotor is turning, I've had them were the distributor gear is stripped
Old Dec 16, 2015 | 08:59 AM
454Luvr's Avatar
454Luvr
This isn't a dwell problem unless the points aren't opening or closing at all. Like someone else said, the gap isn't critical in terms of the motor firing. Many of the potential component failures involved in the ignition system can be eliminated (or confirmed) simply by using an inductive timing light. I would start there. Are you sure this is an ignition problem? Does the carb have pump shot when you pull the accelerator linkage?
To 1973 Corvette, Engine not firing
