Steering wheel alignment
Old Dec 14, 2015 | 09:06 AM
golfboy's Avatar
golfboy
Default Steering wheel alignment
The steering wheel on my 78 Pace Car is not centered. How do I go about getting it aligned properly?
Old Dec 14, 2015 | 09:11 AM
toobroketoretire's Avatar
toobroketoretire
Assuming the steering wheel hub was indexed correctly you'll have to make small corrections at your tie rods.
Old Dec 14, 2015 | 10:20 AM
mikem350's Avatar
mikem350
If you have not done this before be aware that changing tie rods affects the toe in adjustment. Any alignment place can do it, and I know I will get flamed for telling you this.
This is an easy adjustment once its on the alignment rack IF the tech is competent. You can say leave the toe as is, just center the wheel. Or better get latest specs from this site.
Old Dec 14, 2015 | 10:45 AM
AirborneSilva's Avatar
AirborneSilva
Why not just take the steering lose at the rag joint and center it, then there's no chance of screwing up your alignment... Just a thought
Old Dec 14, 2015 | 10:51 AM
SH-60B's Avatar
SH-60B
Never do that. The steering wheel is indexed to the steering box. You won't have the same turning radius left and right.
Old Dec 14, 2015 | 10:56 AM
AirborneSilva
Sorry, that makes no sense, if you take it lose from the steering box and turn the steering shaft to center the wheel it is completely loose from the steering box and has no effect on it...
Old Dec 14, 2015 | 11:02 AM
SH-60B's Avatar
SH-60B
It will drive straight, it won't have the same turns center to full left as center to full right. Center the wheel, then adjust the tie rods to get the wheels straight. Don't Bubba your vette.
Old Dec 14, 2015 | 11:07 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Old Dec 14, 2015 | 11:12 AM
AirborneSilva
You've not explained how it is "bubba" if you completely isolate the steering shaft from the steering box.
Old Dec 14, 2015 | 11:19 AM
SH-60B's Avatar
SH-60B
That's exactly the reason, you have separated them, they are no longer aligned properly. Sorry, I only speak English, I can't really explain it any better.
Old Dec 14, 2015 | 11:25 AM
SH-60B's Avatar
SH-60B
Google it, you can find a better explanation
Old Dec 14, 2015 | 11:33 AM
Peterbuilt's Avatar
Peterbuilt
Default The correct way to do it!
If the tie rod ends are installed correctly then turn each sleeve an equal amount in the same direction to center the steering wheel.
Old Dec 14, 2015 | 11:35 AM
SH-60B's Avatar
SH-60B
No you're right go, ahead and remove and replace your steering wheel, Bubba.
Old Dec 14, 2015 | 11:36 AM
AirborneSilva
I did't say anything about the removing the steering wheel! You need to learn to read...
EDIT: Let me see if I can explain it for the mentally handicapped. So if you remove your steering column and there is nothing wrong with your alignment, then when you put the steering column back in the car you don't screw with the tie rods to get your wheel straight do you? No, when you connect the steering shaft to the steering box you ensure the wheel is straight then. How will that effect your turning radius?
Old Dec 14, 2015 | 11:39 AM
SH-60B's Avatar
SH-60B
Doesn't matter which end you do it from. You need to learn how to think, lol!
Old Dec 14, 2015 | 11:44 AM
AirborneSilva
Okay mr thinker, you're so damn smart then explain how my way will screw up the turn radius... You can't because you can only call names, what a coward!
Old Dec 14, 2015 | 11:46 AM
SH-60B's Avatar
SH-60B
So point out where the OP took his steering column out
To Steering wheel alignment
Old Dec 14, 2015 | 11:49 AM
AirborneSilva
It was an example, I have at least made an attempt to tell you my train of thought, you have only told me I'm wrong and have not explained yourself. You're wasting me time, it's like trying to talk to a brick wall that already knows everything...
Old Dec 14, 2015 | 11:53 AM
SH-60B's Avatar
SH-60B
Goodbye then. Happy motoring, lol!
Old Dec 14, 2015 | 11:56 AM
AirborneSilva
That's the most descent thing you've said to me, ever! Have a great day, I know I will
