Corvette "mongrel" motor question
Old Dec 17, 2015 | 11:04 AM
ronarndt's Avatar
ronarndt
Default Corvette "mongrel" motor question
We have all heard the SB and BB motors referred to as mouse and rat. I think I have one that should be called a mongrel- combination of a couple types. Just love getting a car with little or no info on the motor. I got this 68 convert in July with a "454" motor. Obviously, swapped out the 427 for the later production 454. I checked the engine code stamped on the block and found it was from a 1968 two door full size Chevy- probably that fancy Caprice sport coupe they made. I just ordered spark plugs, based on the assumption that I needed for a 68 454 engine. (it did not occur to me that they increased the Mark IV engine to 454 cu in in 1970) Plugs arrived and they are not correct for the heads on the car. Plugs on the car are the smaller 5/8 inch size. Plugs ordered came as the larger (think 13/16?) size. So- heads on the car do not match the block. I did not check head casting numbers to see what year they are Does anyone know when Chevy switched to the smaller spark plugs? I'm thinking about 1974. So- back to the engine code lists, but I think I may have a 427 block made in 1968 with 454 heads made in ????. Does that make sense?
Old Dec 17, 2015 | 11:30 AM
diehrd's Avatar
diehrd
Sure could be a mix of different year parts, and it may be a lot easier to take plug to a part store and match what you have or cross reference them to any brand you prefer
Old Dec 17, 2015 | 11:41 AM
joewill's Avatar
joewill
sometimes you can see the date code for the head after removing the oil filler cap.. otherwise you have to remove a valve cover to get the casting code and the date code.. let us know what you find.
a 454 is just a 427 with a 454 crank in it.. but due to the longer stroke there have to be reliefs cut into the bottom of the cylinder walls to keep the rods from contacting the cylinder walls due to the longer stroke. the 69 512 block was machined to support this since gm was future engineering the 69 block to support the 454 in 1970.
you most likely have a 427 block..
check the date code in the back of the block behind the distributor and the casting code also. this will tell you what you have.
my book states that the 68 big chevy 427 engine is pretty much the same as the corvette 427/390HP engine so you have a stout engine.
the heads may be a different story, if you have later big block heads they are probably the open chamber heads vs closed chamber for the earlier heads and this will lower your compression and perhaps not be properly mated correctly to your pistons.. dropping your potential power. other opinions may vary...
Old Dec 17, 2015 | 11:42 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Pull the valve covers. Heads have GM part numbers and casting dates under the valve covers. You can often Google GM part numbers.
Old Dec 17, 2015 | 11:57 AM
ronarndt's Avatar
ronarndt
Default motor
"Pull the valve covers" Yeah- that was my next step. I actually had a new set of plugs from a previous engine, but I was ordering the platinum ones. Now I have gotten curious to know what engine I actually have (have written the PO to get info, but no reply). I have the casting number list for the heads and will double-check the block number again. Would REALLY like to know about the cam. Rough idle says it is not the stock cam that was put into the Caprice sport coupe.
When I complete all of the annoying other repairs needed, maybe I will pull the cam and add one I like and know about. Old Corvettes- love them or hate them, depending on the day of the week.
Old Dec 17, 2015 | 02:46 PM
Sayfoo's Avatar
Sayfoo
I have a '69 427 with early 70's 454 heads. Yes, different spark plugs.
I think the previous owner swapped them to drop the compression ratio in order to run low octane unleaded gas.
Old Dec 17, 2015 | 02:50 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
Pull a valve cover and get the head casting number.
Look it up here:
http://www.mortec.com/bbc.htm
Buy plugs for the description.
Jebby
Old Dec 17, 2015 | 03:55 PM
ronarndt's Avatar
ronarndt
Default motor
Sayfoo- that would be my guess also. The 454 can also chug along at low rpm without fouling the plugs.
Old Dec 17, 2015 | 10:43 PM
ronarndt's Avatar
ronarndt
Default engine numbers
well, I went back and re-checked the numbers. found I was reading one of them upside down.
stamped number front of block above timing cover: T0601TST (Tonowanda, June 01, TST is suffix for 454 truck engine in 1978. Should be LF-8)
casting numbers. Passenger side D21 78
casting numbers driver side 861959
Any other info from thee numbers? Is the passenger side number showing 78 as the production year 1978? Is D21 April 21?
My list for the LF-8 shows 20 and 30 for 3/4 an 1 ton. I'm hoping that also means a four bolt block.
Old Dec 17, 2015 | 10:49 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
861959 is actually 361959
73-90 454 2 or 4 bolt
Unless it an original application....the 4 bolt means almost nothing in a street application other than conversation. A 2 bolt block is stronger than most will ever use or build.
Jebby
Old Dec 18, 2015 | 09:45 AM
ronarndt's Avatar
ronarndt
Jebby
"861959 is actually 361959" Jebby- you can not believe how much time I spent trying to decipher that casting number. Part of the raised characters of the numbers were missing from rust or wear. I still would not mind having a four bolt. I re-built a 2 bolt for my truck a couple years ago and you are right- the 2 bolt is a stout engine.
Old Dec 18, 2015 | 09:54 AM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
They can be very hard to see due to crummy Gerald Ford era work ethics...LOL!
Save the above website that I posted...Mortec....great resource.
Jebby
To Corvette "mongrel" motor question
