Best engine mounts?
Old Aug 28, 2002 | 10:16 PM
Blues77's Avatar
Blues77
Default Best engine mounts?
I want the best! None of that power steering pully rubbing, and fan hitting shroud :crazy: . Are energy suspension's any good? They have the trans/motor kit for about $50..
Old Aug 28, 2002 | 10:25 PM
Corey_68's Avatar
Corey_68
Default Re: Best engine mounts? (Blues77)
They have quality parts just be certain they are the poly units which I'm 99% sure they are. :cheers:
Old Aug 28, 2002 | 11:14 PM
Blues77's Avatar
Blues77
Default Re: Best engine mounts? (Corey 68)
thanks Corey. Yes they are poly. Plus they have cool colors.:) .. Ill give them a try.... :cheers:
Old Aug 28, 2002 | 11:16 PM
Corey_68's Avatar
Corey_68
I have used Energy Suspenion on my street rod with great results. You'll like them, great quality.
Old Aug 28, 2002 | 11:25 PM
C3 Shark Tank's Avatar
C3 Shark Tank
I have red Energy Suspension poly mounts, no problems with them at all and they hold up much better than rubber ones to fluids. You can also get them with gold anodizing or chrome metal. Energy Suspensions does not sell direct to the public, you have to get them from a reseller.
Old Aug 29, 2002 | 12:25 AM
theandies's Avatar
theandies
The best part is they are locking mounts, so it the poly does fail the two metal parts of the mount will keep the engine from torquing over causing you fan to hit the shroud (unless you have a very small clearance).
I have the red poly ones with the gold anadized metal.....looks :cool:
John
[Modified by theandies, 10:26 PM 8/28/2002]
Old Aug 29, 2002 | 12:35 AM
SteveG75's Avatar
SteveG75
Default Re: Best engine mounts? (theandies)
Got all three (2 x engine + tranny mount). Work great. With the Tremec, I have about 1/4" clearance between the tunnel and the U-joint on the tranny yoke due to the longer transmission length. No evidence of hitting so far so I am assuming the mounts are doing a good job of controlling movement.
Only issue I had was that the tranny mount is thicker than stock. I left out the spacer plate in order to gain a little clearance per some advice from my tranny guy (Mike Forte).
Definitely worth the $$$.
Old Aug 29, 2002 | 02:13 AM
R. Bruno's Avatar
R. Bruno
Default Re: Best engine mounts? (SteveG75)
Related dumb question- are engine mounts a typical wear item? Should they be replaced after say 26 years?
Old Aug 29, 2002 | 05:44 AM
Rockn-Roll's Avatar
Rockn-Roll
Here's what I think you should get. It will save you $70 and you will never break them:
It's a 1/4" think steel plate from Moroso, they also have them in chrome.
Old Aug 29, 2002 | 07:31 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: Best engine mounts? (Rockn-Roll)
Have the Energy suspension mounts too. They work fine for me and yes, the locking feature is an extra reason to get them.
Marck
Old Aug 29, 2002 | 09:51 AM
Zane's Avatar
Zane
Default Re: Best engine mounts? (Twinnie)
I have them also :D . The mounts are thicker and I used longer bolts than stock. I replaced my 6 engine mount bolts with ones that are 1/4" longer.
Old Aug 29, 2002 | 12:26 PM
verskel's Avatar
verskel
Energy Suspension Poly mounts are the way to go ! :cheers:
Old Aug 29, 2002 | 12:27 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Where did you see the Trans-Motor kit? All I have ever seen was the mounts sold separately for about $30 ea for motor mounts and $20 for transmission mounts. I'm in the market for all three.
Old Aug 29, 2002 | 12:38 PM
Fevre's Avatar
Fevre
Default Re: Best engine mounts? (Smokehouse69)
I have seen them in the summit catalog. Funny thing is the kit cost more than the two individually. I will double check at lunch and post specifics.
Old Aug 29, 2002 | 03:40 PM
Twin_Turbo's Avatar
Twin_Turbo
You were probably looking at prothane, not energy suspension, they're cheaper but not worse in any way. I have installed a couple of prothane poly kits and was very happy with the quality
Marck
Old Sep 1, 2002 | 11:42 PM
GTR1999's Avatar
GTR1999
Anyone have any problems with headers and poly mounts? I have to replace the mounts and was thinking of the poly since the rubber drivers side split in 2- luckly this were GM mounts with the locking tabs. I think it was broke for well over a year in not more, but the fan never hit the shroud.
Gary
Old Sep 2, 2002 | 01:24 AM
The Dude's Avatar
The Dude
Especially since an incident on my first run Saturday. Driver side engine mount broke on launch. Took out the shroud, the fan and the clutch and popped open the hood when the alternator bracket hit it and put a star crack in it. (And still tore off a 1.775 60-foot time and a 12.48 @ 110. :yesnod: )
No more screwing around--solid mounts and dual electric fans in front of the radiator for me.
To Best engine mounts?
Old Sep 2, 2002 | 08:48 AM
Disco_Mike's Avatar
Disco_Mike
Default Re: Best engine mounts? (The Dude)
No problems with excessive engine vibration with the solid mounts?
Old Sep 2, 2002 | 11:48 AM
Edzred72's Avatar
Edzred72
Energy Suspension Poly motor and trans mounts here too :yesnod:
Under heavy torque conditions...that motor sits still!!! You won't be dissapointed.. :cheers: :cheers: :cheers:
Eddie
Old Sep 2, 2002 | 06:13 PM
The Dude's Avatar
The Dude
Default Re: Best engine mounts? (Got79Fever)
That's an issue for some folks. I don't care since Big Orange is officially no longer a street car.
