Desk Top Dyno help PLEEZ
Old Aug 29, 2002 | 12:32 AM
tnt76vette's Avatar
tnt76vette
Default Desk Top Dyno help PLEEZ
Current Set Up: 350 (8.5 Comp), Comp260H Cam, Stock 76cc heads, 1.5 Roller Tip Rockers, Dual Plane Intake, Stock Q-Jet, Dynomax Ceramacoat Headers, 2 1/2" Chambered Pipes..........Coming this winter: 58cc heads with same sized valves. Could someone pleez run this combo thru both ways (b4 and after new heads) so I can see what to expect with next mod? 58cc heads should bump me up to 10.0+ on compression ratio... Thanx in Advance.......This Place Rocks........... :cheers: :cheers: :cheers:
[Modified by tnt76vette, 11:34 PM 8/28/2002]
Old Aug 29, 2002 | 12:46 AM
Scott78's Avatar
Scott78
Default Re: Desk Top Dyno help PLEEZ (tnt76vette)
What 58cc heads? vortech? Changing the heads will alter the numbers.
Here's original setup. There is no way in this program to adjust for particular manifolds or roller rockers.
Scott
[Modified by Scott78, 10:54 PM 8/28/2002]
Old Aug 29, 2002 | 12:54 AM
tnt76vette's Avatar
tnt76vette
Default Re: Desk Top Dyno help PLEEZ (Scott78)
I understand that Scott....I was hoping someone could run it both ways to see how much I would gain by changing these heads..... Heads to be added have casting # 14014416......Thanx for your help.
Old Aug 29, 2002 | 01:07 AM
Scott78's Avatar
Scott78
Those are heads off of an 80-86 305 with 1.84 intake and 1.50 exhaust valves,
going to 58cc brings compression to 10.24:1
Scott
[Modified by Scott78, 11:10 PM 8/28/2002]
Old Aug 29, 2002 | 11:57 AM
tnt76vette's Avatar
tnt76vette
Thanx a bunch Scott78! Not sure I'm gonna do the Head change now....The TQ I'd gain on the bottom end would be lost HP on the mid range and Top End.......Everything we do in Life is a Compromise I guess. :eek: :eek: :eek:
To Desk Top Dyno help PLEEZ
