1968 Temperature Gauge Problem
Summary of Retest:
1. Red wire: 12+ Volts.
2. Black wire: Grounded, in fact it blew the 10 amp gauge fuse when I was careless.
3. Green wire: Continuity only, I did not load check it.
4. I monitored the resistance across the sending unit case and output terminal during engine cool down. The following is a summary of the temperature on the surface of the sending unit and the ohm reading across the gauge:
1. Test Start 240 degrees 103 ohms
2. 25 minutes 135 degrees 130 ohms
3. 40 minutes 125 degrees 163 ohms
4. 1 hr 13 min 101 degrees 195 ohms
5. 2 hr 10 min 96 degrees 1 At initial contact various ohm reading would flash up but then immediately go to 1. Doesn't these results show that the sending unit is good?
Two thoughts, 1) should the gauge unit itself be grounded as if it were setting in the gauge cluster and 2) if my firewall connection was badly corroded could I have continuity but not current flow??
I’m electrically challenged and any and all help will be greatly appreciated. Hugh
So if u measure the pink wire on the gauge to ground it should read exactly batt voltage.
So if u measure the black wire on the gauge to ground it should read zero as the same potential as ground anywhere in the car.
Now the green wire will differ in voltage as the temp of sensor/sender changes.
Ok your resistance readings show a operating thermister with a negative temp coefficient. As temp increases the resistance decreases or in your case as temp decreases the resis increases. I cant explain how 96*F is only 1 ohm but the rest look reasonable.
What u want to do now is "back pin" the sensor connector (green wire) and read the DC voltage (red pos meter lead on the sensor and black neg lead to ground) . This should be the same as what u measure on the same green wire on the gauge terminal (same pos meter wire on gauge terminal and neg meter wire to gnd). U can do this just by attaching extension wires.
I think u find large difference between the 2. Next measure continuity (resistance) from the end of the sensor green wire to the gauge terminal connector for the green wire - resistance should be near zero. Im guessing its not and u need to repair the wiring.
Yes the gauge is grounded through that black wire. The sensor is grounded by its case and sometimes sealant or Teflon tape prevents this - just check resistance from the case to the head (should be near zero). No u really cant have continuity and no current flow in an energized circuit. Now a de-energized circuit with one lead lifted will show no resistance right up to the open in the circuit.
Thats enough for now. Hope it helped.
look at the picture on Wilcox's site and you'll see exactly what I am talking about
On my new gauge, I have 87 ohms across the insulator, 48 ohms across the power/ohm wire leads, 158 ohms across the ohm wire/ground leads, an open across the power/ground leads and 0 ohm from the ground lead to the case. I'm at a loss. Can the circuit inside the gauge burned out?? Hugh
Loose lead is the power lead.
Sure the winding in side can be burnt, I've never ohms tested them because if they are assembled properly and don't work I know they are toast.. but on three gauges, that doesn't make sense unless you have something cooking them.
Cleaned can
No leads connected
The power lead and ground or ohm lead connected
All three leads connected.
I think I just achieved the title “dumbest electrician in the world”. I was attempting to resolve what I initially thought was a simple situation; my temperature gauge did not work. I’m a hobbyist/backyard mechanic that basically was introduced to the more involved auto mechanics working on various Vettes that I own.
Not only did I get some great info from the Forum, the responses were quick and informative. Wilcox details how to assemble a temperature gauge they provided pictures of testing various specific condition that might occur on a unit. Sadly for me they missed the one picture I needed, the one showing the needles position if the pigtail is installed backwards. The needle goes to the far left, just below the ‘100’ mark, the 9:30 position.
Please don’t ask how that could happen as we all laugh!! This Vette's interior was taken apart by me over 15 years ago. I had to remove the interior to get to a broken A/C distribution part and a damaged left side dash. Yes, I forgot how it can apart so I relied on my 1968 AIM. I colored the wire diagram and all. I faithfully refer to the appropriate sections as I rebuilt the car.
When asked by a friend if I installed the connector correctly, I again checked the wire diagram in the AIM electrical section and I did it exactly as it showed; RED lead on TOP, BLACK lead in the MIDDLE and GREEN lead on the BOTTOM. GUESS WHAT, THAT IS *** BACKWARDS!@#$%.
A will admit to my lack of knowledge about auto mechanics but I have years of experience in what should expected of a wiring diagram. When possible any illustration should reflect the parts actual function, ie, you don’t show a normally closed switch as a normally open switch. This diagram leaves a great deal to be desired.
Three gauges (one brand new), a new sending unit and a thread on the Forum later, I started looking into mechanical gauges!! I kept thinking to myself that I somehow reversed the polarity. As part of the search for the mechanical gauge and how electrical temperature gauges worked, I stumbled across a photo showing an electric temperature gauge with the lead colors painted on the gauge's lead. PROBLEM SOLVED.
Where do I pick up my award??
