Oil Pressure sender connection?
Old Jan 1, 2016 | 11:23 AM
wheatpj's Avatar
wheatpj
Default Oil Pressure sender connection?
Four bolts, two fuel lines, and the oil pressure sending connection and the LS5 (1971) is ready to lift out. I’m going to disconnect the oil pressure sender at the oil filter, but the setup (copper line and all) looks rather delicate. Any precautions or tips for getting it off without damage.
Also, any reminders and tips about things I may have overlooked prior to the lift are also appreciated. All the external components (including carb and distributor) have been removed and openings blocked. I am removing the engine w/ trans using a 2 ton lift and a quality leveler attached to the accessory bolt holes in the heads. Grade 8 bolts of course, engaged to at least ¾ of an inch.
Thanks - Pat
Old Jan 1, 2016 | 11:34 AM
toobroketoretire's Avatar
toobroketoretire
If you're not planning on overhauling the transmission its much easier to leave the transmission in and just pull the engine.
Old Jan 1, 2016 | 07:55 PM
wheatpj's Avatar
wheatpj
Thanks - Pat
What about getting the oil sender off without damaging it?
Old Jan 1, 2016 | 09:03 PM
flyeri's Avatar
flyeri
Like Alan says, flare wrenches if you have them. There is no sending unit as with an electric system. Just a brass fitting threaded into the block above the oil filter and a fitting for the line to connect. Get the line disconnected and remove the other fittings from the block with a box end wrench. All of the fittings can be easily replaced if you scuff them up.
Old Jan 1, 2016 | 09:58 PM
wheatpj's Avatar
wheatpj
I have the flare wrenches. My main is twisting the copper line during the removed process. The connection between the small and larger flare nut looks semi-permanent (see pic). There is a midstream connection that looks a little more forgiving. The last thing I want to do is run a new line all the way to the back of the oil pressure gauge. That would a real PITA.
Old Jan 1, 2016 | 10:19 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
If it were me, I would hold the mid section with a wrench and loosen the smaller. Be sure to keep the copper line centered as best as you can to keep from twisting the line.
Old Jan 1, 2016 | 10:29 PM
wheatpj's Avatar
wheatpj
Thanks, That didn't occur to me. I was going to try to hold the small nut stationary and twist the larger. Your way is probably less susceptible to damage. Fingers crossed. If I damage the copper line, I guess I will try to get away with replacing from the midstream connection back to the block.
Old Jan 3, 2016 | 11:37 PM
wheatpj's Avatar
wheatpj
Came right off without a hitch. Engine and trans out too; that wasn't hard either. The worst part was trying to get the motor into the cradle. I rounded one of the motor mount bolts. Fortunately, it was the bottom one. I was able to bend the motor mount back and forth until it broke, which gave access for the cradle to accept the top two motor bolt holes. I'll leave the rounded bolt to the machine shop when the engine is rebuilt.
Thanks everyone.
Old Jan 3, 2016 | 11:43 PM
TimAT's Avatar
TimAT
I was able to bend the motor mount back and forth until it broke, .
Thanks everyone.
Holy Cats!! Remind me to not **** you off!!
Old Jan 4, 2016 | 10:41 AM
BLUE1972's Avatar
BLUE1972
Did you use a lift or just rip it out..
congrats
To Oil Pressure sender connection?
