C3 ls1 swap tach issue
Old Jan 2, 2016 | 03:45 PM
JGoodin86's Avatar
JGoodin86
Default C3 ls1 swap tach issue
So I completed my ls1 swap in my 81 and my tach reads low under 1000 rpm and high above 1000 rpm. I have changed the setting in hptuners from 6 to 3. I have read online about adding in a resistor connected to power to boost the signal but don't know if that will fix my problem. Anyone else have this problem?
Old Jan 3, 2016 | 08:58 AM
Illegal Vette's Avatar
Illegal Vette
Changing the tach setting to 3 worked on my '82, no resistor was necessary.
Old Jan 3, 2016 | 12:09 PM
Garys 68's Avatar
Garys 68
The pullup resistor is typically used when the tach does not function at all, but worth a shot. Can you check the output with another tach to determine if your is bad?
Old Jan 3, 2016 | 12:12 PM
JGoodin86's Avatar
JGoodin86
Thanks. It seems to be working only some of the time. After I reflashed with hptuners it started working. I will see how long it lasts.
To C3 ls1 swap tach issue
