Oversize Holes
Old Jan 2, 2016 | 04:42 PM
SwampeastMike's Avatar
SwampeastMike
Default Oversize Holes
'79
All three of the mounting holes for the screws that hold the trim panel to the driver door are slightly too large. While the screws seem to grab properly upon installation after even a short time on the road they are all quite loose.
I know the old trick of steel wool for slightly loose connections in a bolt/nut type situation but don't know what to do for sheet metal.
Any suggestions?
BTW, I replaced all of the interior screws and they hold fine in the passenger door so I know that that the screws themselves are not the problem.
Old Jan 2, 2016 | 05:13 PM
Mooser's Avatar
Mooser
If they're close (not too much over) and in the steel panel you can usually go around the edge of the hole (maybe 1/16th away from the hole) with a center punch and put about 6-8 "dents" around (automatic center punch) each hole. This will force some of the metal back into the hole and close it up.
If it's more, you really need to get into adding a small piece of tin to the back side of the skin (pre-drill and epoxy it in place) or a u-clip type speed nut may work
M
Old Jan 2, 2016 | 05:24 PM
SoCalErv's Avatar
SoCalErv
Army
There are many ways to tackle this issue:
JB Weld the hole to make it smaller
JB Weld a blindnut behind the hole
Pop rivet some virgn sheet metal behind the enlarged hole, pre drill the new hole
Old Jan 2, 2016 | 06:04 PM
454Luvr's Avatar
454Luvr
That last one gets my vote, and make sure the new metal is a gauge or two thicker than original. You could also attach the new metal with JB Weld or by soldering or brazing.
Old Jan 2, 2016 | 10:48 PM
Kim72's Avatar
Kim72
Here's what I do. Take a small piece of bailing wire, bent 90 degrees, and stick/hook it in the hole. Now mount the panel and screw it down. This makes the hole just a little bit smaller and gives the screw something to "bite" into. Usually works for me.
Old Jan 2, 2016 | 11:00 PM
GUSTO14's Avatar
GUSTO14
I learned this trick from my Father back in the 60's. He always used a piece of copper wire however. He said it was softer and would conform to the screw easier and there was less of a problem with corrosion.
Good luck... GUSTO
Old Jan 3, 2016 | 10:45 AM
chevygod's Avatar
chevygod
Wire trick here too, but I use paper clip wire. Same idea, forces screw to side of hole helping it snug up.
Old Jan 3, 2016 | 10:53 AM
SwampeastMike
Thanks for the wire idea!
No offense to the others, but that sounds like the most practical--especially for the upper rear hole with almost zero access to be back side.
Old Jan 3, 2016 | 12:04 PM
Ibanez540r's Avatar
Ibanez540r
Not what I was expecting...
Old Jan 3, 2016 | 01:23 PM
redrdstr72's Avatar
redrdstr72
FWIW, I have the luxury of having a great fastener shop not far from my office. There, they stock many, many fasteners, including sheet metal screws with a smaller head size than normal for the body of the screw. For example, if I have an oversized hole problem with a size 6 screw, I can buy a size 8 screw with a size 6 head. This shop can almost always match the type head and proper plating, thereby making the repair invisible with no extra work.
From first hand experience, I know this is how the assembly plant made corrections like this. They used what is commonly termed a "repair" bolt/screw/etc.
Hope this helps...
Old Apr 2, 2016 | 06:57 PM
SwampeastMike
It's been a while since I posted this but I finally decided to try this fix after the front screw for the arm/rest door pull also came loose and refused to hold. It was simple and worked BEAUTIFULLY. Thanks!!!! I used 16 gauge aluminum wire.
Old Apr 3, 2016 | 10:41 PM
pltmgr's Avatar
pltmgr
I have some success with plastic drywall expansion anchors
Old Apr 3, 2016 | 11:58 PM
Kim72's Avatar
Kim72
Your welcome. Pretty simple but it usually works.
To Oversize Holes
