DISCREPANCY ON STANDARD FRONT STABILIZER BAR SIZE
Old Aug 29, 2002 | 11:26 PM
Runner81's Avatar
Runner81
Default DISCREPANCY ON STANDARD FRONT STABILIZER BAR SIZE
I was just thumbing through Richard Prince’s 68-82 Restoration Guide and was surprised to see the standard front stabilizer bar for all 78-82s listed as .875” (page 220). 1.112” was listed for the FE7 equipped cars. I thought I recalled the factory specs for my ’81 stating that both the standard and FE7 front bars were 1.112, and that the FE7 included a rear bar.
I’ve based a lot of suspension mods on my car having the larger sized bar. I don’t do my own mechanical work, don’t have access to a lift, and can’t put my hands on factory specs. Can someone please confirm?
Old Aug 30, 2002 | 01:49 AM
flynhi's Avatar
flynhi
Default Re: DISCREPANCY ON STANDARD FRONT STABILIZER BAR SIZE (Runner81)
This info should be in the AIM.
Regardless of OE, there are many CF folks using 1 1/8 front bars sucessfully.
Old Aug 30, 2002 | 02:07 AM
mapman's Avatar
mapman
Runner81,
I don't know if my 1980 came with the FE7 suspension. However, the car appears original with#s matching throughout. The front is 1 1/8 inch diameter and the rear bar is 7/16 inch diameter.
If you have not already done so, you might get the opinions of several of the suspension specialists to make sure what you're building is appropriate for how you're going to use the car.
Old Aug 30, 2002 | 02:57 AM
IronJen's Avatar
IronJen
Abby Normal
Veteran: Marine Corps
i think that may be wrong. my '81 was a base coupe (non FE7) and it came with a 1-1/8" bar. i had no rear bar. i am 98% positive the front bar was never changed since i have known this car since 1984.
Old Aug 30, 2002 | 05:40 AM
UKPaul's Avatar
UKPaul
Default Re: DISCREPANCY ON STANDARD FRONT STABILIZER BAR SIZE (clutchdust)
My '81 also has a 1-1/8" front bar & no rear bar.
:cheers:
Old Aug 30, 2002 | 10:12 AM
flynhi's Avatar
flynhi
Good advice from Mapman. Check with Guldstrand and Vette Brakes before mixing OE with upgrades. The C3 suspension can be VERY unforgiving if set up wrong.
Old Aug 30, 2002 | 10:27 AM
redvetracr's Avatar
redvetracr
runner,
Wouldn`t it be easier to just measure the front bar on your car?? And if you or ANYONE ELSE doesn`t have a rear bar and wants one I have a NOS GM 7/16 bar. ...redvetracr
Old Aug 30, 2002 | 12:02 PM
Runner81's Avatar
Runner81
Default Re: DISCREPANCY ON STANDARD FRONT STABILIZER BAR SIZE (flynhi)
I don't have the AIM, or I wouldn't be asking this question. Do you have the info?
Old Aug 30, 2002 | 12:05 PM
Runner81's Avatar
Runner81
Default Re: DISCREPANCY ON STANDARD FRONT STABILIZER BAR SIZE (mapman)
Most of the work is already done, as per the advice of Corvette suspension experts (including DS, GD and other CFers). My quandary is that I based it all on the front bar being 1.112.
Old Aug 30, 2002 | 12:30 PM
Runner81's Avatar
Runner81
Default Re: DISCREPANCY ON STANDARD FRONT STABILIZER BAR SIZE (redvetracr)
Redvet:
As per my initial post, I don’t do my own mechanical work, don’t have access to a lift, and can’t put my hands on factory specs. So it’s not possible for me to measure at this point. I already have a 7/16 rear bar, and "hopefully" a 1.112 front...
Anyone have the AIM specs for the standard '81 bar?
Old Aug 30, 2002 | 08:44 PM
Chris69's Avatar
Chris69
Mine are also standard at 1 1/8" on the '81, with no rear bar.
Old Aug 30, 2002 | 08:51 PM
Zack Wenning's Avatar
Zack Wenning
redvetracr,
I was thinking about buying a rear bar for my 69 which did not come with a rear bar. If the rear bar you have is of no use to you i would love to have it for at least the cost of shipping.
Thank You
Old Aug 30, 2002 | 09:04 PM
redvetracr's Avatar
redvetracr
Default Re: DISCREPANCY ON STANDARD FRONT STABILIZER BAR SIZE (Zack Wenning)
zack,
"shipping" from me to you would be about $110.
...redvetracr
Old Aug 30, 2002 | 10:58 PM
Runner81's Avatar
Runner81
I just received a l-o-n-g fax of the 1981 MVMA Specification Form (MVMA-C-81) issued by Chevrolet in 1980 for the '81 Corvette. Bottom line: The 1.112" front bar was the only bar offered - both with the standard suspension and the FE7. The FE7 cars added a .44" (7/16") bar.
I'm not sure what Mr. Prince was smoking while compiling his research. For the time being, I'll assume my bar is the bigger one until my shop gets my car on the lift to trim the coils and adjust the spring bolts. Thanks to all for the feedback.
To DISCREPANCY ON STANDARD FRONT STABILIZER BAR SIZE
