Drivers shoulder harness will not release
Old Jan 11, 2016 | 02:08 AM
Dale002's Avatar
Dale002
Default Drivers shoulder harness will not release
The shoulder harness on the drivers side of my wife's 78 will not release. It's stuck in the retract position. Is there a way to get it to release?
What are my options?
Old Jan 11, 2016 | 04:01 AM
slickfx3's Avatar
slickfx3
the material is thin, the angle and positioning is in a bad spot, it's old technology, my new set does the same thing
you have to pull it straight down slowwwwwwly and smooth out all the folds( bc it so thin)...i had to throw mine out
not to mention it's expensive and 250.00 plus
Old Jan 11, 2016 | 09:02 AM
jnb5101's Avatar
jnb5101
The weights inside that extend when the belt is moved rapidly are stuck. You should be able to disassemble it and clean and lubricate(very lightly) them.
To Drivers shoulder harness will not release
