My Alt needs more excitement!!!
Old Jan 13, 2016 | 01:47 PM
hugie82's Avatar
hugie82
Default My Alt needs more excitement!!!
Hey guys, I've been doing research on these new self exciting alternators and can't seem to find a way to get my alt to turn on without Revving the engine. I find it a problem in the cold weather, I'll go out to warm the car up but I don't want to rev a cold engine and it will take a few tries before it turns on. I have all 3 Oem wires connected and it charges great when it turns on but I'm wondering if there's a jumper wire or capacitor I can install to light it off or do I have a bad alternator and need to return it. Thanks for reading.
Old Jan 13, 2016 | 01:53 PM
MelWff's Avatar
MelWff
I have seen one wire alternators but what is a 3 wire "self exciting"? Who makes it? Did you use a hand held voltmeter to check what the reading is when you turn it on? What rpm is your fast idle set for?
Old Jan 13, 2016 | 02:01 PM
gungatim's Avatar
gungatim
do more research on them. that is how they work, by leaking current. very inefficient and not recommended...why do you think the OEM's don't use them?
btw, there is a way you can put in a momentary switch to get it to start charging without revving it, it's what we use in tractor conversions, but for all the work, why not just put the proper alternator back on?
Old Jan 13, 2016 | 04:07 PM
toobroketoretire's Avatar
toobroketoretire
Its very common for the single-strand wire in the side plugin to break inside the insulation right next to the terminal and when it does break it often takes a revving engine to vibrate enough for the wire to make contact. Those side plugins are available from any auto parts store for about $5.
Old Jan 14, 2016 | 09:32 AM
gungatim's Avatar
gungatim
no that's not why, the reason is because the iron core is magnetized slightly and revving it fast enough through the windings produces a very weak current which is used to excite the alternator when the RPM's are high enough. that is how they are designed, otherwise they would be fielding out when you try to start the engine when it turns over...bad...you also give up the remote voltage sensing of a regular alternator, which isn't a big deal on a tractor or boat, but on an old vette with all the wiring connections and aged terminals? you're just asking for trouble...
Old Jan 14, 2016 | 08:23 PM
hugie82's Avatar
hugie82
Thanks every body. I checked the 2 prong plug and it's been replace. Connections are good. Voltage gauge works perfect. I purchased this alt from Advanced auto. I'm pretty sure most of these alternators are a one wire setup but they leave the side plug for the gauge, I've also seen them advertised as either/or.
I am interested in that switch that excites the alt. I too have some old tractors and will be looking at coversions when their charging system goes to the happy hunting ground. I was thinking of using a capacitor from my old Harley. The old bikes had a huge one to keep the headlight steady at idle. That should excite an alt pretty good!
I just have no idea how to wire it in? I can build any engine, manual trans and most things mechanical but electricity befuddles me at times. I'm just not sure what exactly is going on inside that alt to start hooking wires to it. That and the $90 I spent on it
Old Jan 15, 2016 | 10:57 AM
gungatim's Avatar
gungatim
First of all, you need to see if you truly have a "1-wire" alternator, and not just some hybrid. if you have the 2 spade plug wires hooked up, what are they hooked to? what are they doing? that plug is normally blocked off on a 1-wire alternator. If the 'F' is hooked up, and getting power with key on, but not running, it will start the alt. charging immediately when running. you say this is not happening. either it is not hooked up correctly, or it is going nowhere in the alternator as it was replaced with a 1-wire regulator. a true 1-wire alternator is set to charge at a lower RPM than a pseudo-1-wire...
not having power on the 'F' or #1 terminal will make you rev the engine to get it charging (voltage leakage). if your alt light in the dash is burned out, it won't charge until you rev it as well.
before I go into any more detail you really need to post exactly what you have, where you got it, model#, pics, etc...
Old Jan 15, 2016 | 11:13 AM
68blvert's Avatar
68blvert
http://www.madelectrical.com/index.shtml
Read the tech section on 10Si/ 12Si AND 1 wire alternators. Explains it all
Old Jan 15, 2016 | 11:50 AM
gungatim's Avatar
gungatim
great link, hadn't seen that one before. I usually refer people to the pirate 4x4 page but will start using that one as well (simpler graphics).
fyi from his link go to "electrical tech' at the top and scroll down...
Old Jan 15, 2016 | 05:19 PM
hugie82's Avatar
hugie82
http://www.quietcanyon.com/images/rrdelwiring.jpg
Talking to the guys at advanced auto. I wouldn't call them gurus or even weekend wrenches but they made a few calls and said the alternator can be used as a one wire or a 3 wire. I found this on a few sites. Taking the hot key wire and running it to the hot side will make it turn on but why doesn't it work that way thru the plug? Maybe I'll make up a jumper wire and see what happens. I'm pretty sure I won't ruin anything by doing this. What say you?
Old Jan 15, 2016 | 05:22 PM
hugie82's Avatar
hugie82
Thanks for the link, at first I wasn't sure what I was looking for and now I just found it. Thanks!
Old Jan 15, 2016 | 05:53 PM
centuryoldracer's Avatar
centuryoldracer
I have had this problem and returned the alt. for another one, and solved the problem. It can be the alt.
A cheap easy way to have a one wire is to use a GM alt. that is new enough that it does not require an external voltage reg. Like a 1978 or something around that year. Simply jump the Two spade connectors together, and run the big wire from the alt. strait to battery positive. You do have to rev this set up one time on start up to excite the field, and kick it into charge mode.
We used to upgrade old boats with this set up. It would work on anything if you fabricated the brackets to mount it.
Old Jan 17, 2016 | 12:22 PM
hugie82's Avatar
hugie82
I can return it, I still have a few months to do so but I really like how well this alt charges. If I can't figure out a way to turn it on sooner, I'll bring it back.
Old Jan 17, 2016 | 02:24 PM
454Luvr's Avatar
454Luvr
Isn't that the purpose of the battery and regulator? No modern alternator/regulator/battery system should need such a thing, either to steady the lights or to start the alternator.
Old Jan 19, 2016 | 12:40 PM
gmachinz's Avatar
gmachinz
The stock GM charging system routing leaves A LOT to be desired. Add modern electrical devices and it gets worse. Voltage drop is the biggest killer. 2nd issue is cheap offshore rebuilt alternators using sub-standard rectifier diodes, stators, regulators, ect. I prefer to upgrade to a late model designed engine harness when doing any kind of serious electrical upgrades.
Old Jan 19, 2016 | 02:52 PM
gmachinz's Avatar
gmachinz
There are options other than an SI to fit the stock brackets-using a CS130 from an '88 Olds Firenza 2.0 FI bolts directly in place of the SI with the same clocking-just swap the serpentine pulley out for your v-belt style and upgrade the plugin to the CS style. Then solder inline on the "excite" wire a 50 watt 1/2 amp resistor and a diode if you'd like and you'll be setup with 105A from a better designed alternator-at least internally speaking.
To My Alt needs more excitement!!!
