Clutch throw-out/Fork?
Old Jan 16, 2016 | 02:52 PM
wheatpj's Avatar
wheatpj
Default Clutch throw-out/Fork?
How easy should the throw-out bearing slide on and off the clutch fork? The throw-out bearing slips right on and off mine. Initially I thought the tips of my retainer springs were worn, but I googled pictures, some spring were flat and others had pointed spring tips. See pic of mine.
Old Jan 16, 2016 | 04:15 PM
toobroketoretire's Avatar
toobroketoretire
Default Throwout Bearing
The throwout bearing isn't a tight fit at all. Just slides on and off.
Old Jan 16, 2016 | 04:55 PM
wheatpj's Avatar
wheatpj
It slides right on, but if I'm not careful which way I orient the bellhousing, the throw-out bearing will slide off the clutch fork. Should it be that loose?
Old Jan 16, 2016 | 05:23 PM
tracdogg2's Avatar
tracdogg2
The end of your fork is bent. You need to straighten it or replace it.
Mike
Old Jan 16, 2016 | 05:30 PM
wheatpj's Avatar
wheatpj
Mike
Thanks, I will replace it.
Old Jan 16, 2016 | 09:42 PM
croaker's Avatar
croaker
You can just buy the clip from Willcox instead of buying a new fork for a crispy hundred bill. I wish I'd known that when my clip broke
Old Jan 16, 2016 | 09:49 PM
wheatpj's Avatar
wheatpj
i saw the clip, but if the end of the fork is bent, it is probably best to replace it.
Old Jan 16, 2016 | 11:29 PM
croaker's Avatar
croaker
I looked all over wound up going GM for replacement
Old Jan 16, 2016 | 11:44 PM
wheatpj's Avatar
wheatpj
I ordered one from Zips
Old Jan 17, 2016 | 09:36 AM
Street Rat's Avatar
Street Rat
Ordered one from Summit Racing.
http://www.summitracing.com/parts/na...ibanner=SREPD2
Old Jan 17, 2016 | 11:51 AM
wheatpj's Avatar
wheatpj
Originally Posted by Street Rat
I saw that one, but I was a concerned about the review. With the speed of Summit's shipping it will be to my house before Friday so I can set engine in car over the weekend. I may give it a try. Thanks
Old Jan 17, 2016 | 12:28 PM
hugie82's Avatar
hugie82
You made the right choice, replacing the arm will give you piece of mind until your kids inherit the car from you. Just match them up before installing to be sure you have the right arm. Yours might have a slight bend and that does happen from years of use with a heavy pressure plate springs. Good luck.
To Clutch throw-out/Fork?
