So on my 81 I've got the short factory headers/tube manifolds And they got some small cracks around the welds and the flange that the exhaust bolts are on broke. Does anyone know if the headers are 304 or 308 stainless or something different?
Well from what I've read they were pretty notorious for that. Mine happened to be a little self inflicted when I was bolting the exhaust back on. At least on the driver side. As for the passenger side I haven't got to pull if off yet but I can see someone has put some kind of tape around it so I figure it has a crack something. So far on the driver side header there is no crack on the welds just the flange that bolts it to the exhaust. When I originally posted the guy who we bought the car from had a set I could have but there were some cracks on the welds so I just assumed mine had them to because I know I've had a leak and that was before the flange broke off.
Another thing and I'm no metal expert but the flange looks like mild steel definitely not stainless. It has rust all over it has anybody had experience with this?
Well on mine the flange that has the 3 studs that bolts the header to the exhaust broke on me. When I inspected it the welds were pretty crappy at best. there was no penetration on on the welt just stuck on there and there was rust in between the welds and flange
well i didn't mess with that at all,
to my surprise when i was able to remove or loosen all the top bolts
i thought I would have a fit to "separate" the headers from the head, but the headers simply "fell" away from the heads and i was able to drop the gasket sections in without further ado
perhaps instead of welding, you may source a used one on ebay?
or if you live in a state that allows go for a set of "real" headers?
