Dipstick Tube
Old Aug 30, 2002 | 08:30 PM
NJ74STINGRAY's Avatar
NJ74STINGRAY
Default Dipstick Tube
HI Guy's, Looking for the best way to hold dipstick tube in place.Any suggestion's on which epoxy sealer to use.Thanks,>STW< Frank :flag
Old Aug 30, 2002 | 08:40 PM
Rogue Wave's Avatar
Rogue Wave
CI 4-5-6-7-8 Veteran
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-16-'17
Default Re: Dipstick Tube (NJ74STINGRAY)
My dipstick tube is very tight in the hole.
I'm no expert, but in the few engines I've done I never used sealant on the dipstick tube, they all fit tight in the hole.
Old Aug 30, 2002 | 09:50 PM
vettfixr's Avatar
vettfixr
Mine is loose too. I hope you get a good response because I could use it too.
Old Aug 30, 2002 | 10:09 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Dipstick tubes imo have a one time use. They are a little over sized when new so they fit snugly in the block. You could use a little JB weld if both surfaces are free of oil. I bought a chrome aftermarket tube that even had an o-ring and it worked great. :cheers:
Old Aug 30, 2002 | 10:13 PM
gdh's Avatar
gdh
Default Re: Dipstick Tube (yellow 72)
I just bought a new chrome one when I built the engine and it fit snug.
Old Aug 31, 2002 | 03:45 AM
The Dude's Avatar
The Dude
Since I'm a function-over-form kinda guy I use JB Weld. Holds in there like there's no tomorrow, but it's still (relatively) easy to chip off at rebuild time. Great stuff, JB Weld.
Old Aug 31, 2002 | 04:04 AM
Stoge's Avatar
Stoge
Default Re: Dipstick Tube (The Dude)
You got that right. I have an irreplaceable broken radiator trim piece on my motorcycle... glued it together with JB years ago. Still strong as can be.
Old Aug 31, 2002 | 05:20 PM
Jim 77's Avatar
Jim 77
Default Re: Dipstick Tube (Simon Alexander)
I also used JB Weld. I used it just on the tube itself. Applied, let harden, and sanded. I had to sand it a few times to make it small enough.
It isn't good as new. But it no longer falls out on it's own.
Old Sep 1, 2002 | 01:25 PM
NJ74STINGRAY
Default Re: Dipstick Tube (Jim 77)
HI Guy's,The new Tube went in pretty firm so I am not going to put nothing on it for now.I will check it out after a few drives and see how it is.Thanks for the help.>STW< Frank
To Dipstick Tube
