Engine alignment help please.
Old Jan 24, 2016 | 06:13 PM
wheatpj's Avatar
wheatpj
Default Engine alignment help please.
I have my new engine (big block 4-spd) sitting in the engine bay, but the mounts are off about a half a bolt-hole width everywhere. Right now the engine is sitting on a pair of Philips point screwdrivers though the engine mounts and frame. The trans output shaft needs to move towards the driver’s-side. Everything is out a half a bolt-hole width….the trans mounting holes are out that far if I pull on it really hard. I’m confident the mounts are okay; they are new OEM style from Zips Corvette. I have tried wiggle the engine every which way but it won’t it line-up. The frame is solid but it is possible it may be out a plumb. Any help and suggestions are greatly appreciated.
Thanks, Pat
Old Jan 24, 2016 | 07:04 PM
jnb5101's Avatar
jnb5101
The engine is intentionally off-set to the passenger side. Did you remove an engine from this frame, or is it a replacement frame or a project that came without an engine mounted? The "horns" may have collapsed over the years and leaned inward. Or the frame may have been damaged in an accident. I've seen dimensional diagrams on the web that should allow you to measure and compare your frame.
Old Jan 24, 2016 | 08:13 PM
wheatpj's Avatar
wheatpj
This was an engine swap, big block for big big block. Last year, I lifted the old motor out of its mount to change the harmonic balancer; engine dropped right back into to alignment. The new engine won't align, out about a half a bolt-hole width. The frame may be out of plumb. I need some advice on how to finesse or shim the engine into place.
Old Jan 25, 2016 | 04:39 PM
crf311's Avatar
crf311
What type of mounts are you using? Solid, Rubber or poly? I just installed mine and had to do a lot of wiggling , pushing and pulling to get the bolts in.
I got one side in then worked on the other side. Is your fuel pump mounted on the block? I could not install my bbc with it on. I had to install the fuel pump after I had the motor bolted in. It kept hitting on the upper a arm. Check it out.
Old Jan 25, 2016 | 04:59 PM
Danish Shark's Avatar
Danish Shark
Are the spacers between the block and the mounts missing?
Old Jan 25, 2016 | 06:58 PM
wheatpj's Avatar
wheatpj
What spacers? I didn't know there were suppose to be spacers. That would probably remedy the problem. What do they look like and are they available in the Corvette parts catalogs?
Old Jan 25, 2016 | 07:20 PM
jnb5101's Avatar
jnb5101
I think the spacers were for A/C cars only. They are V shaped metal plates about 1/8' thick inserted between the engine and mount.
Old Jan 25, 2016 | 09:01 PM
wheatpj's Avatar
wheatpj
I saw some v-shaped spacers on Summit’s site. They are 3/16 thick, looks like the application is intended to address clearance issues. Given the angle of the block, they would move the mounts mostly outward, which is the direction I need to go. The engine that got swapped out was a #s matching 1971 LS5 non-A/C motor. The engine mounts could have been original to the car. Unfortunately, I throw them away so I have nothing to compare.
The mounts I am trying to use are rubber OEM style. The vendor description is 70-82 Engine Mount w/interlock. The manufacture is Auto Extra part#2267 from what I can read thru the Vendor’s sticker. Could it be the mounts? Anybody have any opinion of mount that might match up better or be more forgiving of subtle frame misalignment.
I might try taking up some weight with a jack under the front cross-member (on the edges of course) to see if I can’t finesse the bolts into position. I’m looking for advice.
Old Jan 25, 2016 | 10:10 PM
Jebbysan's Avatar
Jebbysan
Dr. Detroit
You may need to "clock" the assembly......one side is up and one side down.....but when it gets out of whack it "swings" kinda like a hammack and can be very frustrating to locate the blots.....
See if you can get one bolt in and then post a pic of where the other falls....
Jebby
Old Jan 25, 2016 | 10:50 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Good info in here for rookies like me!
Old Jan 25, 2016 | 10:54 PM
wheatpj's Avatar
wheatpj
Jebby
I won't get to it until this weekend. I will post (pics) regarding my progress or lack there of. Thanks
Old Jan 25, 2016 | 11:04 PM
CanadaGrant's Avatar
CanadaGrant
Those shims are for AC cars only and raise the front of the motor very slightly. The GM "reasoning" behind this was to keep the carb float level after the extra weight of all the AC stuff. Do as Jebby says. Drop the motor in with all the weight still on the hoist. Get the lowest mount lined up and stick something like a phillips screwdriver through the one side of the mount to line up the hole and insert the bolt through the opposite end. Then repeat on the other side but keep the tension on the hoist until you have it lined up with the bolt in. If you just drop it down you will never get the bolts in. Good luck.
Old Jan 26, 2016 | 02:20 AM
pauldana's Avatar
pauldana
The engine/transmission is offset to the rear end, you must keep this offset or you will get harmonic vibration at various speeds, especially around the 60-80mph range.
The drive shaft is in a Z type alignment with the transmission and rear end.
So, if you are trying to get this in a perfect alignment ... Don't
Old Jan 26, 2016 | 12:33 PM
crf311's Avatar
crf311
I also raised my 454 3/8"between the block and motor mount for better header clearance.
Old Jan 26, 2016 | 02:22 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
The smart way to drop an engine in is to leave the mounts to the block loose. Meaning all three bolts on each side are loose. Drop the engine down and line up the bracket so you can can slide the long bolt thru. Don't tighten the long bolt yet.
Next tighten up the 6 bolts ( 3 on each side ) to the block. Next tighten the long bolts. You are now finished. If you think this won't work I have done it this way for years, even when I take an engine out for work and put the same engine back in.
Old Jan 26, 2016 | 03:44 PM
Danish Shark
http://www.zip-corvette.com/68-82-c3...ount-shim.html
I couldn't get my Big Block in without using those shims. The bolts were about half a bolt thickness out of alignment without them.
Old Jan 26, 2016 | 09:26 PM
wheatpj's Avatar
wheatpj
That seems like a good strategy, thanks for the tip.
To Engine alignment help please.
Old Jan 26, 2016 | 09:38 PM
wheatpj's Avatar
wheatpj
Thanks everyone for all the great information. I won't get to it until the weekend, but I feel a lot better knowing there are a number of things I can try. I will post back on my progress.
Thanks again
Pat
Old Jan 31, 2016 | 06:37 PM
wheatpj's Avatar
wheatpj
The engine is in ; I used MoterHead's method. Loosening the block to engine mount bolts allowed me to align the engine so I could get the transmission bolts in too. just tightened the bolts, worked great.
Many thanks
Pat
Old Feb 1, 2016 | 10:08 AM
keithinspace's Avatar
keithinspace
CONGRATS!!! I had a somewhat similar issue, but it ended up that my frame was bent sometime along the way.
Glad to hear yours was easier to correct.
