76 Parking Brake Cable Adjustment
Old Jan 25, 2016 | 11:27 AM
BEVO76's Avatar
BEVO76
Default 76 Parking Brake Cable Adjustment
I am restoring the rear suspension in my 76 over the winter months.
I have most everything back together with exception of the parking brake cable.
The ball at the end of the cable is about 2in short of the clip behind the rotor. I am having a hell of a time getting it back on the clip. If I take the rotor off I can easily get the ball on the clip. But with the rotor on the cable with the ball on the end is well short and I cannot get the ball to reach the clip.
Is there any way to get some slack out of that cable to get the ball on the clip?
BTW! Fun fact.....I learned last night why you torque the spring plate bolts with the car on the ground. New differential cover is on the way. Have to redo everything.....lesson learned.
Old Jan 25, 2016 | 11:46 AM
Peterbuilt's Avatar
Peterbuilt
Is the nut behind the equalizer backed off?
Old Jan 25, 2016 | 11:52 AM
BEVO76's Avatar
BEVO76
I am not sure. I didn't touch anything when I took it apart. Now that I am trying to put it back together the cable is short.
I am assuming that "A" is the nut that I need to back off in order to get some slack in the line?
Old Jan 25, 2016 | 12:01 PM
Peterbuilt's Avatar
Peterbuilt
There are two nuts, A is forward and B is at the rear. Loosen B.
Old Jan 25, 2016 | 12:24 PM
BEVO76's Avatar
BEVO76
Perfect that is exactly what I was looking for.....much appreciated.
How much slack can you get from loosening it? 2-3in worth?
I assume I just crank it tight once the ball is installed?
Old Jan 25, 2016 | 12:32 PM
MelWff's Avatar
MelWff
No you do not just crank it tight. There is a procedure for adjusting the parking brake which involves adjusting the shoes and after they are set you pull the brake handle a certain number of clicks and then adjust the nuts so that there is a slight drag. If you have the factory Chassis Service manual it has all the details.
Old Jan 25, 2016 | 02:53 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
A larger picture of what Pete posted.
Old Jan 25, 2016 | 07:42 PM
BEVO76's Avatar
BEVO76
Thanks everyone for the support and pictures. This has helped out a lot. Much easier to understand.
One more question I am tracking that the rear leaf spring is supposed to be torqued while the car is on the ground and that the 4 bolts holding the spring up should be torqued to 50lbs. Is this correct?
Old Jan 25, 2016 | 07:44 PM
BEVO76's Avatar
BEVO76
BTW you guys at Willcox are on it!!! I might have to start buying more parts from you guys. Thanks for the support.
Old Jan 25, 2016 | 08:06 PM
0Willcox Corvette
Former Vendor
The rear spring should be snugged up when in the air, the let down and torqued. The factory spec from the AIM was 60-80 ft lbs.
Willcox
Old Jan 25, 2016 | 10:15 PM
ZAKsPop's Avatar
ZAKsPop
Hope not to seam too ignorant but this diagram tells what to do to adjust the parking brake, unfortunately, I don't know how to do it. What tool do I use to measure cable tension? My parking brakes all all but useless. Needless to say I have my wheels chocked.
Old Jan 25, 2016 | 11:54 PM
BEVO76's Avatar
BEVO76
First line one of the larger open holes on the rotor with the tension star on the bottom of the parking brake. Look through the hole when lined up on the bottom and you will see the tension star / sprocket....or whatever you want to call that thing. Use a flat tip screwdriver to adjust the tension up and down. If that dosent work you will have to adjust the cable.....which is where im at.
Old Jan 26, 2016 | 01:04 AM
ZAKsPop's Avatar
ZAKsPop
Sorry! You lost me.
So I use a screwdriver to adjust the tension but how do I determine what the tension is? It says the front cable should be 30 lbs. +or- 3 lbs. How do I tell?
Old Jan 26, 2016 | 01:23 AM
BEVO76's Avatar
BEVO76
Sorry! You lost me.
Pm me ur phone number it would be easier to talk through this then post on the forum. That could take days.
Bo
Old Jan 26, 2016 | 12:42 PM
MelWff's Avatar
MelWff
Default Adjustment
Sorry! You lost me.
Apply the parking brake two notches. Adjust the nut on the cable so that you feel a light drag when turning the rear wheels.
To 76 Parking Brake Cable Adjustment
