LED Headlights
Jan 30, 2016 | 05:59 AM
LED Headlights
LED headlights are a relitively new piece on the market over the last couple years, as such I am not up to speed with them. I want to replace both low and high beams with them. My question is, does anyone know if the bi-LED bulb would be used as the low beam and the plain LED bulb would be used in the high beam position, or would you use both bi-LED bulbs in both positions?
Bi-LED
http://hidkitpros.com/shop/5-h5006-r...ht-conversion/
Regular LED
http://hidkitpros.com/shop/5-round-s...ed-conversion/
Jan 30, 2016 | 10:34 AM
I have not seen these. Are they a direct replacement?
Jan 30, 2016 | 10:38 AM
The OEM bulbs were dual element on the low beam and single element on the high beam. So I would figure it would be the same with LEDs.
Jan 30, 2016 | 12:34 PM
I would call or email them to make certain.
Jan 30, 2016 | 08:01 PM
Ok, so dual element on the low would be a Bi-led, and the single on the high would be the straight up led. That's how I'll attack it. Thanks.
Quote:
Originally Posted by
vetteguy22
They ought to be. Let me spend $400 and find out first
Jan 30, 2016 | 08:42 PM
If they fit, and have lower amp drain, they might eliminate the need for extra relays (to assure full brightness).
Jan 30, 2016 | 09:27 PM
mikem350
The site claims the bi-LED @ 3.00 Amp @ 12v.
an H5001 rates @ 3.90 Amp @ 12v.
Should be slightly less amps. 3.6 less amps all together.
Just ordered 2 bi-LED and 2 straight LED. We will find out the results on Weds.
Jan 30, 2016 | 09:47 PM
This is my next task, better lighting.
I'm on the edge of my seat................
Jan 30, 2016 | 10:05 PM
Jan 31, 2016 | 09:21 PM
led
Feb 1, 2016 | 07:57 AM
2024 C5 of the Year Winner - Modified
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Feb 1, 2016 | 08:02 AM
Are the any particular Before and After shots or videos you guys would like to see?
Feb 1, 2016 | 12:59 PM
Based on the power draw they should be significantly brighter than the OEM bulbs.
Feb 1, 2016 | 01:26 PM
AW IR C3
Perhaps a comparison (change 1 side only) up against the garage door, or down your drive way. Just to see if there is a big difference from stock.
Feb 1, 2016 | 06:56 PM
Feb 2, 2016 | 07:42 AM
Kubs
Ok.
I'll also try to get a shot of amp draw too.
Feb 2, 2016 | 10:17 AM
I currently have the front nose off and the head light buckets out this is very timely for me. I am going to have to replace all 4 headlights. Looking forward to seeing how you like this and was it a direct plug and play? I don't want to have to rewire anything. Just plug in the new lights and move on.
Feb 2, 2016 | 07:30 PM
Looks like shipping is delayed until Thursday. Gonna have to hold on another 24 hours guys
Feb 3, 2016 | 08:50 AM
I will be patient and wait nicely in the corner...
Feb 3, 2016 | 10:53 PM
Glad to let you spend the $400 first. Maybe by the time l am ready for them they will only be $200! LOL
