Quick q jet question
Old Aug 31, 2002 | 12:56 PM
dogboy's Avatar
dogboy
Default Quick q jet question
Where on the q jet does your vac advance line connect to. Mine is in the upper front drivers side outlet. I am pulling vac. at idle from this port?
Old Aug 31, 2002 | 03:26 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Quick q jet question (dogboy)
It will be a port that does not pull vacuum at idle. It should only pull vacuum past idle. If all your ports are pulling vacuum at idle, then your idle speed is set too high and you have other timing / idle mixture issues.
Old Aug 31, 2002 | 09:36 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
If you look at the front of the carb, it is the port on the lower right . It is to the right of the protrusion where the fuel filter is.
Old Aug 31, 2002 | 10:16 PM
dogboy's Avatar
dogboy
Default Re: Quick q jet question (Big Fish)
thanks guys
To Quick q jet question
