Another 3.36 or 3.54 thread...
I dont like running at such high highway RPMs either, but I am going to address that with a 700r4. And this is a fun car, not a road trip car too.
This is the only way to do it. I removed my Th-400 and 3:08 gears and put in a 700-R4 and 3:73 gears. WOW!!! what a Sweet change
If I had to the option to do it all over, I would do the Exact same Change-Over
It's a blast when you're 17-18 , it sucks when your 30+ Trying to cruise to the show 30 miles away.
Its the absolute best of both worlds.. I did mine 7-8 years ago ...w/525HP .. THE Best choice in my opinion
L82 cars came with 3.55 from factory ...had 2 , even without locking Torque Converter I drove them to Florida and back many times on the Interstate ..
Mike
I really want the overdrive because the high rpm just makes me uncomfortable and seems to run a higher risk of overheating when everything isn't in tip-top shape.
My tranny is a Super T10 with 2.88 first (very low) so I will have overall ratio of 10.2 with the 3.54 gears, and 9.5 with the 3.31's. I've never swapped gears before so I don't know how much different these will feel. I am leaning towards the 3.31 just because of the highway rpm's unless someone can convince me that's not a big deal. Price is the same for both, so that's not a consideration. This is a job that I only want to do once, so I will live with it. And I just did the tranny, so that's not changing.
Engine is a warmed over crate 350 with vortec heads and XE268 comp cam.
Hope this helps... Crash
Back when I was still just thinking about all this, I built an Excel spreadsheet so I could make comparisons. I especially wanted to compare the difference in 1st gear leverage with the '82 to the various ratios I've used in the past with standard 3-sp autos. I have a pretty good idea how earlier C3s run with different motors and ratios, so it's not too difficult to look at the numbers and determine what's required for what I'm hoping to accomplish.
Just one example of how I'm using this...
My '72 454 had a TH400 and 3.70 rear. Looking at the spreadsheet, it's immediately apparent that 1st gear would have provided an overall "launch" ratio of 9.18. There's no close duplicate for that in the new ratios, but that's OK, I'm no longer running that motor. Now, the motor is much smaller and more anemic. So, I know if I want to get close to the 1st gear acceleration of the 454, I'll need a much shorter ratio, probably something close to a 4.56. That gearing would have provided an overall 1st gear ratio of 11.31 in the old days, and based on the sheet, I can duplicate it using the 700R4 and 3.70/3.73 rear end.
On the other end of the scale - highway cruising - the old 454 with a 3.70 would have been turning at almost 3,200 RPM at 70 MPH. The 700R4 will reduce that to roughly 2,200, even after I make the gear change. In fact, hwy cruising RPM is reasonable with virtually any ratio. Nice!
The spreadsheet lets me enter any tire diameter, and it recalculates globally using that number. Also, the right side of the sheet lets me enter a fixed RPM as a shift point, and it calculates vehicle speed at that RPM for the 700R4 with various rear ratios.
If anyone would like a copy of this sheet, just send a PM.
I know the 82 had a 700 and a 2.87 but most importantly it had fuel injection and that was the key to that combo. Even though it was not ideal had they put a carb on it the car would have never been able to utilize that over drive and lock up. It would have stumbled kicked and bucked like ya had egg shaped tires lol
