Fan blower question
Old Feb 4, 2016 | 08:46 AM
jgcable's Avatar
jgcable
Default Fan blower question
I removed the AC in the engine compartment and plugged up my manifold and waterpump inlets and outlets to my heater core. My question is this. I am buying that ACdelete cover so that I can retain my original AC heater core. It will allow me to install my factory blower. If I do that and I hook the wiring harness up to it will the fan work normally with the exception of obviously not having any heat or AC? I was thinking that having the ability to blow air into the cabin couldn't hurt.
Old Feb 4, 2016 | 10:46 AM
tracdogg2's Avatar
tracdogg2
The blower will work fine as long as you remount the blower relay and resistor block. Nothing changes in the wiring.
Mike
