Lower control arm shaft issues (also: calling VB&P)
Old Feb 6, 2016 | 12:08 PM
worship79's Avatar
worship79
Default Lower control arm shaft issues (also: calling VB&P)
Busy on my 'While I'm at it' front end project and I ran into a snag reassembling the lower control arms.
Parts were blasted and powder coated; shaft ends were blasted too, but not coated. Currently installing the VB&P full poly kit, which includes the 31024 and 31028 poly bushing sets with new inner sleeves.
First off a question: who uses loctite on the retaining bolts?
Secondly: I have two issues I sent VB&P tech an e-mail for their opinion on the matter yesterday, but of course I'm way to impatient to wait for their answer. Monday is looming already, so I decided to throw out a line to the trusty forum as well
1) A small crack in the tip of the shaft end.
My first thought was to simply file it down; thoughts?
2) Two of the new sleeves don't reach the shoulder completely.
This seems like I can just sand down with some fine grit paper. Correct?
Or were these pressed on in the factory? The AIM does not share very much information on the matter. After bolting things down the sleeves aren't supposed to move anyway, right?
Thanks in advance guys!
Old Feb 7, 2016 | 06:56 AM
worship79's Avatar
worship79
Anyone?
Old Feb 7, 2016 | 07:43 AM
jim2527's Avatar
jim2527
Originally Posted by worship79
Anyone?
Half the country is still sleeping....patience grasshopper.
Old Feb 7, 2016 | 08:56 AM
Mooser's Avatar
Mooser
I'd tighten in a bolt into that shaft and have a real good look to see if it is actually cracked and just closed up and not visible. Likely your fine, especially since it's all trapped inside the bushing even if it way but JIC. I only say that since it looks sharp like a crack rather than a dent.
As for the bushings. The originals had teeth on the ends of the inner sleeve that locked into the face of the arms there to prevent them from rotating and the rubber twists during use. Hence the "tighten with the suspension loaded" bit.
The poly will slide on the shaft/sleeve even after tightening so the sleeve doesn't lock in. I would expect that sleeve to slide all the way on past that little ridge onto the shoulder once you tighten the bolt.
Just my $.02
M
Old Feb 7, 2016 | 11:26 AM
centuryoldracer's Avatar
centuryoldracer
Just my $.02
M
I agree. I think it will be OK to assemble as is. Don't over think it.
Old Feb 7, 2016 | 05:15 PM
worship79's Avatar
worship79
Yeah, sometimes I forget the time difference
Old Feb 7, 2016 | 05:20 PM
worship79's Avatar
worship79
M
Great idea! I'll try that first thing tomorrow.
Yes, well... I'm sort of a "why keep it simple, if it can be made complicated" kind of guy. Hence this whole 'while I'm at it project' I got myself into But thanks!
Old Feb 7, 2016 | 05:49 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
My $0.02 worth, regarding Loctite....
I used the VB&P bushings on a C-3 about 20 years ago. I didn't initially use Loctite on the retaining bolts, and one backed out. Fortunately I caught it before anything serious happened. Therefore, I strongly recommend using Loctite on those bolts.....red Loctite.
Old Feb 7, 2016 | 06:32 PM
Mooser's Avatar
Mooser
Yes, well... I'm sort of a "why keep it simple, if it can be made complicated" kind of guy....
I can relate to that.
M
Old Feb 15, 2016 | 06:52 PM
worship79's Avatar
worship79
Bushings (well, the shells) are in! Did the nut test and no crack appeared, so I'm good
Man, getting those lower control arm shells in is a real PITA!
To Lower control arm shaft issues (also: calling VB&P)
