ENGINE WAKES UP!!
Old Aug 31, 2002 | 11:49 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default ENGINE WAKES UP!!
I had the motor professionally done and tuned by the best Rod shop in San Diego but I knew it was not realizing it's true potential. Today my cousin Kenny came over and we swapped out plugs/ wires (8mm Taylor) checked out the distibuter(stock with Hypertech/ MSD guts) advanced it another 4 degrees. And adjusted the fuel ratio on the Eldebrock carb. It still has a momentary flat spot at 2000-2300 RPM but after that it runs like a raped ape! . :D I took her down to the beach to cruise and got a hair up my butt. At the light I punched it and started going sideways (no 225/70's here, soft compound 255/45/17 tires) then straightended it back up and at 35 MPH at 3500 RPM I PUNCHED IT and shifted to 2nd and it spun tire 75 ft down the road (yeah nothing for you BB guys but what used to be a 210 HP stock SB :eek: ). Also keep in mind I'm running 2 1/2" Hookers straight back to Monza mufflers (you can see straight through them) and at full throttle it sounds like the world is coming to an end. I caught out of the corner of my eye a group of people ducking back into a store as I passed by as if a Sherman tank or F-14 at full afterburner was hauling butt down the street. I probably can be heard 5 blocks away. This thing is unreal!! :smash: :smash: I still need to solve the small flat spot but the torque off this 4X4 cam is sick!! All these months I never knew what I had under the hood, Kenny if your out there YOU ROCK!!!!! :cheers: :cheers: I do not recommend and condemn my childish driving on public streets but it was SOOOO COOL!!! :jester
[Modified by Cali,77,L-82, 9:51 PM 8/31/2002]
[Modified by Cali,77,L-82, 11:18 PM 8/31/2002]
Old Aug 31, 2002 | 11:58 PM
fauxrs's Avatar
fauxrs
Default Re: ENGINE WAKES UP!! (Cali,77,L-82)
Arrrrrghh, I was planning on going down to the beach today, even thought of the possibility of seeing you down there again.
sounds way :cool: - are you going up to the clairemont cruise tommorrow (sunday?) if so I will surely be there.
congrats - I'm getting very antse about building my new motor - perhaps its time I started.
Old Sep 1, 2002 | 01:19 AM
Cali,68,L-79
Default Re: ENGINE WAKES UP!! (fauxrs)
Fauxrs you won't be disappointed! Vroom!!
Old Sep 1, 2002 | 01:25 AM
Double Aught's Avatar
Double Aught
I think I will check it out tomorrow.
Old Sep 1, 2002 | 01:42 AM
Cali,68,L-79
Default Re: ENGINE WAKES UP!! (sd pacecar)
I'll see ya both tommorow, say 1200?
David (619) 729-3130
Old Sep 1, 2002 | 01:43 AM
Double Aught
Sounds good to me, it will give me time to eat breakfast and then wash my car.
Old Sep 1, 2002 | 02:14 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
It's really nice to get some HP out of these old motors. My speedo goes to about 80MPH, now that's good for second gear !
Hey isn't there a beach down there called Blacks Beach or something like that, can't remember the early '80's were a little fuzzy. :D
Old Sep 1, 2002 | 04:38 AM
Cali,68,L-79
Default Re: ENGINE WAKES UP!! (MotorHead)
I happened upon black's Beach by accident while surfing. It's not all cracked up to be as it should. I think I saw Rosanne's look alike naked and haven't been right since. :crazy:
:jester
To ENGINE WAKES UP!!
