Experience with electric fans?
new technology... same computer controlled motors as used quad copters and drones... and Half the noise level... Half the current draw, Half the weight....Twice the efficiency.
http://www.deltapag.com
EDIT: man that is awesome pricing for a whole kit with controller! what did you use, a single 14inch?
I live in so cal... 110 in the summer 427 650hp engine... Cooling just fine:-)
Yea... Pricing is amazing for what you get....
I have no idea why anyone would want to buy a brushed fan now with what options are avlable in brushless computer controlled units...
And I left out... Nearly zero EMI so if you ever go computer controlled fuel/spark FI... You are much less likely to have problems and interference!
I see brushed fans like flat tappet cams.. Yea they work... Great in the day.. But why would you go flat tappet when you can go full roller???
What good reason is their to stay with brushed?
1. Half the noise
2. Half the current draw
3. Always maintains a constant speed regardless of driving conditions
4. Almost 0 EMI
5. Half the weight
6. Reasonable price
7. No brushed also means they will last longer..
It's a beast!
You will need a good 70 amp continuous use relay, 50 amp circuit breaker and 10 gauge wire to feed it.. You'll also need a 140 amp alternator to run it correctly.
You will gain about 15 rwhp getting rid of the clutch fan and going to an electric (assuming the electric is not running when you dyno).
And I left out... Nearly zero EFI so if you ever go computer controlled fuel/spark FI... You are much less likely to have problems and interference!
1. Half the noise
4. Almost 0 EMI
5. Half the weight
6. Reasonable price
1. Half the noise
4. Almost 0 EMI
5. Half the weight
6. Reasonable price
is this the technology of supercars?
anyhow, mundane as mine is, it's fine for my cruising chores
I sent it back, went back to my dual spals and controlled off the ECU and no more issues.
I think there is benefit to the Brushless technology but not until Spal gets a better handle on the logic/control of the fans...
Meanwhile, an 18 year old Lincoln MKVIII fan will blow the doors off of any other fan for cooling, they run forever and you can get them for $100, plus about $75 for good relays/wiring. Throw it on and forget it..
When moving here almost 19 years ago, I just mounted a C4 license plate piece to the holder and not thought much of it....not realizing the plate holder came off and I had a center section to match the outer sections.....and when I made THAT discovery the summer traffic overheating was cured.....but till not happy with the clearance .....so went Dual Spals and ran the wire directly off the alt, forward to the control relay that is actuated by the FI computer and of course they cool immediately, shade can be 100f, figger that black tarmac, and in traffic easy 130f ambient.....the wires are ~8 ga both ground and power off the alternator.....run through a ~2" fuse link near the alt.....yeh, they loud, who cares?? it's a convertible.....
It's a beast!
It's an awesome fan you won't regret it .... Mine is a single 17"
Maybe Spal doesn't have it together but Delta PAG does. AND at $385 for compleat computer controlled brushless fan.. And if you don't use there ecu like I do not, as my EFI turns it on and off.. Now its like $225...
O! And by the way... MADE IN THE USA!!!
Mark VIII
Taurus
Now lets talk about electrical draw: Once the fan gets rolling the drain is minimal (20-25 amp?), and an 86 amp alternator is sufficient so long as you're not burdening it with other electronics (sound system etc). The draw to be concerned about is the first 5 seconds of run up time or the 1 or so second ramp up between low and high speed. Now I'm going off memory here but from what I recall if you turn the fan from off to high the amp pull is a exponentially diminishing ~140amp for that 5 seconds. This is a fire concern. Not immediate but over time it can cause the wire to degrade. Now power wise this is fine to power off of battery, but in the C3 the battery location makes this a bit tricky because of additional load due to wire length. In my Malibu the wire runs through a 70 amp relay and about 1' of 8 gauge wire direct to the battery which gives me a satisfactory margin of safety vs fire. To run from the battery up to the radiator you'll probably want to run a 4 gauge battery wire to a distribution block up under the hood and then take off with your 8 gauge from there.
Availability and price: These Mark VIII fans can be found in a bone yard for about $50-75 or on ebay ~$150-250. (be careful that you identify the fan properly, because nearly all the fans advertised as Mark VIII are actually Taurus fans. People assume because the electrical connector can fit into either that they are the same fan.
My experience: I run one of these Mark VIII units on my Malibu, and my friend runs a Taurus on his Malibu. At low speed the fans are identical but the high speed is starkly different. My Malibu rarely gets over 175~180 even in the hot summer months in traffic. My friends Malibu is usually in the ~200-205 range during the same season. (FYI the radiator core size on my g-body Malibu is identical to the C3, just vertical not at an angle)
Why the difference? Ford made the Taurus with the single speed fan because it had a separate fan for the AC condenser. The Mark VIII just used the main fan unit for both engine cooling and ac condenser heat exchange; hence the 2 speeds.
I hope this helps clear things up.
As for why Ford chose that style of fan, I've discussed this very issue with one of the internal engineers at Siemens Group Canada who built the original motors for OEM Ford applications and Ford wanted a fan motor robust enough to quote "run for 24 hours per day, seven days a week for 10 years if need be" because those motors will bebused in service duty police package Crown Vic's and higher end luxury models (Mark VIII).
Ford owns the fan blade/shroud patent design, Siemens holds the fan motor patent design. Now that has expired however so that's why you see Chinese Dorman copycats on the market. I sold these fans in kits when they were available from the dealer and even an engineer @ Spal (Mark K) said their controller (all 3 defunct versions of it) could not reliably run the Mark VIII fan because it was the most powerful fan they've ever bench tested for airflow and current draw.
I designed my own 3-speed conversion harnesses for it without issue but beyond that the only other Variable speed controller I've seen handle it would be the Delta Current Controller from DC Controls.
I agree its the most powerful fan you are going to find but since they are obsolete from Ford now, and I don't trust the offshore copycat fans, I'd toss my vote to the 2010-up Mustang GT fans now....I've been building those kits for awhile now and they are an equal to the Mark VIII in terms of performance.
For the record, current draw on the Mark VIII fan with my harness is on average 11, 19 and 24 amps for low, medium and high speed. There are ways to wire a big ole fan without worrying about insane inrush current or voltage spiking....butnusing just a single relay to trigger them on/off, yeah....that will cause some issues for you.
I would no do the swap without switching to a newer style alternator. The high current 10SI based alternators are just forcing a higher current into a design never intended for it. The result is poor low speed/idling current output. For this reason. I would only use a CS130, CS144 or AD244 alternator.
Using a higher current alternator then means the charging wiring needs to be upgraded. A heavier wire between the alternator and the solenoid is required. You may want a junction block under the hood to connect other accessories to.
I read cases of people recommending to run the wires right to the battery. It makes absolutely no sense to run a 6 gauge charging wire to the battery when there is a 1 gauge wire between the solenoid and the battery. Use it and save yourself some wire. Same with running the fans. It makes no sense to run a 10 gauge wire right to the battery when there is a hugely oversized wire compared to the current the fans need already run to the solenoid. Just take advantage of the wire from the battery to the solenoid that already exists.
This is 100% wrong.
The mechanical fan is required to operate from 600rpm to 6000rpm and move air at all those speeds. So, the whole design is a compromise, both the fan blade and clutch. The electric fan is designed to operate at a single speed and the efficiency of the design can be optimized at that speed.
See above posts, the MarkVIII, which moves a huge amount of air, is listed to draw 24A at high speed, which is about 0.45HP of electrical load. Assuming the alternator is about 75% efficient, this is 0.6HP.
Look at these links,
http://www.network54.com/Forum/21565...+Fan+Dyno+Test
http://www.carnut.com/ramblin/dyno.html
The first link is great, it shows the same 0.6hp used by the electric fan in their tests. It also shows you can gain about 18hp with electric fans vs a heavy duty thermal clutch fan.
The second link showed about 19hp loss for the thermal clutch fan, assuming it wasn't engaged. The second link gives some testing of the effect of the inertia of the mechanical fan. It is also interesting to note that he had issues with the thermal clutch locking up at high rpm.
This is 100% wrong.
I'm not sold on the brush less fans yet-not fully embraced by the OEM's yet so I'll sit on the fence awhile longer with those fans.
I had an electric fan on mine but went back to stock because the fan mounted on the tilted radiator would create a minor dust storm under the car, messing up my clean and shiny engine bay (not to mention annoying people walking near by).
