Chrome brackets
Old Feb 13, 2016 | 06:08 PM
ENCSDOUG's Avatar
ENCSDOUG
Default Chrome brackets
After tearing out the carpet in the rear section of my 72, I found 2 chrome metal brackets attached to the back side of the fender wells. What are they for? Seat belt guides?
Old Feb 13, 2016 | 06:12 PM
ignatz's Avatar
ignatz
I'm guessing you don't have a rear window tray? Those would probably be the pivots, although I don't remember them being chromed. A picture?
Old Feb 13, 2016 | 06:22 PM
ENCSDOUG's Avatar
ENCSDOUG
I do have a window tray. The brackets were hidden under the carpet. They appear to be possible tie down points. They're soaking right now to get the old carpet glue off. They are U shape around 2" long & 1/2 " tall. They look like this but shorter.
http://www.zip-corvette.com/72-74-se...-hardware.html
Old Feb 13, 2016 | 06:48 PM
ENCSDOUG's Avatar
ENCSDOUG
Originally Posted by Alan 71
Hi e,
You found the "footman loops".
The 2 you found plus 1 located on the bulkhead right behind the seats have a strp that clips to them to secure the roof panels if/when they're stored back there.
Regards,
Alan
From the owner's manual.
You can see the 3rd loop on the center of the bulkhead.
Yeap that's them although I'm missing the one on the bulkhead. Thanks!
Old Feb 13, 2016 | 06:51 PM
Peterbuilt's Avatar
Peterbuilt
They should be on TOP of the carpet.
The strap keeps the tops from falling out if you flip your Corvette upside down. LOL!
Old Feb 13, 2016 | 07:46 PM
ENCSDOUG's Avatar
ENCSDOUG
I kind of figured they should be on top of the carpet. The previous owners had them under. I'm in the process of replacing the carpet.
Old Feb 14, 2016 | 08:35 PM
kansas123's Avatar
kansas123
Default oh
so that's what that stupid thing is! I never tried to find the two in the back since i didn't know what the center one was; I hope my shop that's replacing the carpet puts them back in, just so they're there; probably won't ever use them for that purpose, but would be nice that they are there,
Old Feb 14, 2016 | 09:22 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Old Feb 15, 2016 | 08:10 AM
marshal135's Avatar
marshal135
Veteran: Marine Corps
Hey Alan,
when did they change from 2 single straps to a single hold down?
My 68 has 2 separate hold down straps.
Thanks,
Marshal
Old Feb 15, 2016 | 11:24 AM
ENCSDOUG's Avatar
ENCSDOUG
Hi W,
Are you also reproducing the little 'spacers' (part #3781287) that are used in mounting the 'loops'?
These are often gone when I look at various car's interiors.
If you are that would be pretty nice.
Regards,
Alan
There were (2) rubber spacers on each screw. Mine were in bad shape. I found a vendor who sells the install kit that includes the spacers. They are used to keep the tie downs above the carpet.
Old Feb 16, 2016 | 03:57 PM
ENCSDOUG's Avatar
ENCSDOUG
Default Carpet replacement on my 72
Ok, you guys helped me on what I found under the old carpet which turned out to be footman loops. Now I found (2) what appears to be black foam sitting above both rear tire wells. What are they used for and do I need them?
Old Feb 16, 2016 | 05:03 PM
Mooser's Avatar
Mooser
Foam blocks about the size of a bar of soap or big foam chunks (which somehow I relate to a map of Texas even though they aren't even close) or ???
Maybe a picture would help
M
Old Feb 17, 2016 | 06:55 AM
ENCSDOUG's Avatar
ENCSDOUG
M
Yes, that's about what they look like. A map of Texas. They were easy to pull out. Don't think I'm putting them back unless there is a significant reason they should stay.
Old Feb 17, 2016 | 07:06 AM
sray454's Avatar
sray454
Those foam blocks ( Texas shaped ) slip in above the the carpet on the front side of wheel well and are for sound deadening.
Old Feb 17, 2016 | 07:46 AM
ENCSDOUG's Avatar
ENCSDOUG
Hi ENSCD,
You mention the spacers for the footman loops.
On my 71 the spacers are a short pieces ("1/4"?) of what appears to be something similar to copper tubing that is under the loop on each screw and holds the loop above the carpet.
Doesn't the screw just compress the spacer if it's rubber?
Regards,
Alan
Alan,
Mine were about a 1/4" but were made of hard rubber. I was able to pull them off the screw with pliers. Not sure if they were original or not. I'll find out when my parts come in from ZIP. Using material like copper or metal would be better as you explained. They're being used as spacers.
Old Feb 17, 2016 | 02:13 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Probably doesn't apply to earlier C3s as someone would have mentioned it but on later C3s the 2 rear "loops" are under the carpet with a slit in the carpet for the strap bracket to go under and attach to the loop.
79
Old Feb 17, 2016 | 04:12 PM
0Willcox Corvette
Former Vendor
Original cars varied in the use of the spacer and the number of loops but all cars from 1968-1976 used the metal spacers only. If you have a plastic spacer it is not original.
Original T-top Straps Bracket and Spacers pictured above.
1968-1970 cars used 2 straps, 4 screws and 4 spacers
1971-1976 cars used 3 straps, 6 screws and 6 spacers. The two rear strap brackets used two spacers per screw as shown above, the forward bracket used 2 spacers. While the assembly manual doesn't show the spacers used on 1976 it is wrong! We have taken three samples from cars for our verification.
1977-1982 cars used 3 straps and 6 screws (shorter) and No spacers. Design changes to the rear floor incorporated a bump in the fiberglass instead of using spacers.
A common issue with reproduction screws was created by an error in the GM parts book. The parts book listed the wrong screw size #10-32 7/8″. This is not correct. The correct screw was NOT A machine screw it was a tapping screw and can be found on our website. Some vendors have corrected this but I just looked at two that are still selling the machine screw.
https://willcoxcorvette.com/corvette...68-82-ea-26588
Alan- I have bids out on the spacers right now. I know they are being made already but they are not correct either. Close enough to work though and you'd never know it. But I'm bidding out the exact size and material. The original size of the spacer was 1/4" long, 5/16 od, 3/16 id.
-Willcox
To Chrome brackets
Old Feb 17, 2016 | 06:20 PM
Mooser's Avatar
Mooser
Originally Posted by Willcox Corvette
...... The original size of the spacer was 1/4" long, 5/8 od, 3/8 id.
-Willcox
5/8 OD? Wow, were/are mine ever wrong
M
Old Feb 17, 2016 | 08:13 PM
0Willcox Corvette
Former Vendor
Hi W,
Thanks.
It's one of those LITTLE details!
It would be a shame to have that nice reproduction loop and not have the relatively simple parts to make it actually mount properly!
Regards,
Alan
I'm trying Alan.. But it's hard!!!
Short cuts are the easy way out... I'm trying for the real deal first. It's like the door panel upper screws and/or the wiper relay. The screws are wrong and that relay has been garbage for years now. If you are going to put the effort into it... do it right.. huh?
Mooser.. yeah.. they are pretty small. If you look at the picture above those are original spacers and they are not much larger than the screws that hold them down.
- Ernie
Old Feb 17, 2016 | 08:33 PM
Peterbuilt's Avatar
Peterbuilt
Default Details, details!
Call me Bubba but a couple of washers from a sink faucet repair kit are good enough for a part that no one will ever see.
