Grease Question
Old Feb 16, 2016 | 10:27 PM
Giddy-up Go's Avatar
Giddy-up Go
Default Grease Question
This is the synthetic grease my FLAPS sold me saying it is for wheel bearing and the 600 degree temp rating is within standard. Couldn't find a temp rating on my old traditional mineral wheel bearing grease, so I am somewhat skeptical. I know some FLAPS are better than others and some are less than optimal. Overall this one has been OK, but I just don't want to put the wrong grease in and have it tear up on the maiden voyage whenever that may. Can anybody confirm or deny that this is the right grease for the wheel bearings?
Thanks for chiming in!
Old Feb 16, 2016 | 10:50 PM
Peterbuilt's Avatar
Peterbuilt
That is not for wheel bearing:
You need 3330:
http://www.crcindustries.com/ei/prod...aspx?id=SL3330
Old Feb 16, 2016 | 11:20 PM
ddawson's Avatar
ddawson
If your going to stay with Sta Lube I would use this
http://crcindustries.com/ei/prodtree_ss.aspx?id=212
I use this http://lucasoil.com/products/grease/red-n-tacky-grease
Old Feb 17, 2016 | 12:05 AM
spdrcr29's Avatar
spdrcr29
Originally Posted by ddawson
Me too
Old Feb 17, 2016 | 12:31 AM
Giddy-up Go
Thanks guys! Didn't think it was right! Will check out the Lucas1
Old Feb 17, 2016 | 04:49 AM
croaker's Avatar
croaker
Flaps? I assume a Auto Parts Store
Old Feb 17, 2016 | 05:43 AM
fishslayer143's Avatar
fishslayer143
That's not Wheel Bearing grease... DO NOT USE IT.. that's to lubricate the slides and brake parts ,cables etc.. Whoever sold you that is clueless
Old Feb 17, 2016 | 12:09 PM
Giddy-up Go
Friendly Local Auto Parts Store A term I found here on the Forum!
Old Feb 17, 2016 | 12:10 PM
Giddy-up Go
And that is the problem with FLAPS!
Old Feb 17, 2016 | 02:48 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
What's a FLAP I don't have my acronym decoder ring on right now, I only wear it at work in an Engineering Dept.
Old Feb 17, 2016 | 03:02 PM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
Red Line makes a synthetic grease for CV joints and wheel brgs. I bought it for my Formula Car and use it on everything now. Great stuff !
Old Feb 17, 2016 | 10:07 PM
Giddy-up Go
Friendly Local Auto Parts Store -FLAPS.
Old Feb 18, 2016 | 09:31 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
For my wheel bearings I use Timken grease. Bought a few rubs off amazon.
To Grease Question
