Upgrade Rocker Arm
Old Feb 18, 2016 | 07:19 AM
newbie2vette's Avatar
newbie2vette
Default Upgrade Rocker Arm
It's been s while, but I remember an episode on "Horse Power" TV show. They replaced the stock stamped rocker arm with a roller type alluminum version, it was even mentioned about some hp gain. Has anyone done the same upgrade? Where did you get them and which did you use? thank you.
Old Feb 18, 2016 | 08:33 AM
bashcraft's Avatar
bashcraft
If there's nothing wrong with your stock rockers, you'll be better of to spend your money elsewhere.
Old Feb 18, 2016 | 10:20 AM
MelWff's Avatar
MelWff
based on various sources, not just the cam manufacturers, the stamped steel production arms appear to have only about a 1.37 ratio as opposed to the specified 1.5 ratio. So switching to something like the Competition Cams roller tip rockers at 1.52 or 1.6 ratio may provide a minimal improvement without having to go to full rollers.
1.37 ratio article http://www.crankshaftcoalition.com/w...cam_adjust.pdf
http://www.summitracing.com/parts/cca-1412-16/overview/
Old Feb 18, 2016 | 10:39 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
If you want roller rockers no sense going half-way with them. Might as well get the full roller type for the about the same money.
http://www.summitracing.com/int/part...1-16/overview/
Old Feb 18, 2016 | 03:41 PM
GBC's Avatar
GBC
Default Roller rocker
Hot Rod mag. did an story on hopping up chevys ZZ5
Stock vs. roller was worth 11.2hp. and 4.6 lb-ft. 1.5 to 1.5
1.5 to 1.6, 18.9 hp, 7.8 lb-ft
Hot Rod April 2016
Don't over look cooler oil temp and less friction.
Old Feb 18, 2016 | 03:44 PM
gjohnson's Avatar
gjohnson
I put 1.6 roller tip rockers on my mildly built 350 and noticed it moved the the powerband from low end to the mid.
Old Feb 18, 2016 | 06:05 PM
69FASTFUN's Avatar
69FASTFUN
I am planning on new heads and 1:6 roller rockers and I found this article.
http://www.hotrod.com/how-to/engine/...er-ratio-test/
REELAV8R's Avatar
REELAV8R
Aluminum full rollers may not fit under your stock valve covers. Roller tip magnums will.
Old Feb 23, 2016 | 06:49 AM
newbie2vette
Thank you! Got the heads out and completely clean to start the lapping the valves. I have a set of old aluminum M/T valve cover I will use to replace the stock.
Old Feb 23, 2016 | 09:23 AM
GUSTO14's Avatar
GUSTO14
In the 60's and 70's many times we discovered that switching to a performance cam in SB Chevy's and Ford's with stock stamped steel rockers would result in occasionally snapping of rocker studs. We would elongate the slots a bit with a dremel or other grinding point to eliminate this problem.
In the late 70's I built up a 302 Ford for a Mustang I had. I used a Crane Fireball hydraulic cam and periodically would snap one of the rocker studs. I made a fixture that allowed me to measure the slot in all of my rockers. What I discovered was that the slots varied by as much as 10 degrees. I then opened the rocker with the longest slot 5 degrees on each end and matched the remainder of the slots to that one. Never broke a stud again.
Quality roller rockers, along with having a more precise ratio and somewhat less friction, also allow more slot angle that the typical stock stamped steel rockers.
Good luck... GUSTO
Old Feb 23, 2016 | 09:10 PM
Sayfoo's Avatar
Sayfoo
You can switch from stock factory (nominal 1.5 ratio) to 1.6 ratio, long slot rockers and gain a little on your cam as long as you have enough room that your valve springs don't bind up. Roller trunion rockers will reduce friction a little but you won't notice any difference. Roller tip rockers are a total waste of money. 430 hp LS3 (c6 corvette) hare roller trunions but not roller tips. Roller tips have been shown to just slide over the top of the valve stem, not roll. I originally thought that they would spin, but now believe that they don't.
The stock rockers may or may not have different ratios. Who do you believe? Chevy or the after market crowd that wants your money?
If anything, going to the 1.6 would be the most cost effective for a minimal hp gain on a stock engine.
Old Feb 23, 2016 | 09:47 PM
rcread's Avatar
rcread
I went with Crane Energizer full roller rockers, 1.6:1 under tall valve covers.
Old Feb 23, 2016 | 10:22 PM
Racer11's Avatar
Racer11
I have Hdy roller lifters with a roller cam and rockers on a balanced motor and I love them. And there was no need to break in the cam when the engine was first started, instead I just took off down the road and gave her hell to break in the rings.
Old Mar 16, 2016 | 06:36 AM
newbie2vette
I should received the new set of rockers (1.6:1) anyday now, what I wanted to know if I can use the stock push rods or do I need to get a new set. the stock are in great shape, I did not noticed and major wear pattern on them. Thank you.
Old Mar 16, 2016 | 07:25 AM
MIKE80's Avatar
MIKE80
World Products iron 64cc heads 2.02 intake 1.60 exhaust valves 200cc intake runners with Crane Gold Series aluminum rockers 1.52 ratio on a 385 stroker. I think most of the parts were bought from Summit Racing.
Old Mar 16, 2016 | 07:53 AM
fishslayer143's Avatar
fishslayer143
When I built mine, I went with a huge Roller Cam so naturally I went with Full Roller Rockers .. I chose SCORPION .. little more $$, but MADE IN USA right here in Florida and . Lifetime free replacement warranty. Had them since 09 , I regularly spin 6800 rpm , with .578 lift cam .. no issues. . LOVE THEM .. You will need tall covers
Old Mar 16, 2016 | 08:52 AM
hugie82's Avatar
hugie82
With the heads out, have them decked to bring up the compression and us a MLS head gasket that compresses to .030
The bump in compression and 1.6 ratio roller rockers will wake the car up nicely. Just keep an eye on the rocker studs if they are the pressed in style. They sometimes will start pulling out and you now this by the amount of threads sticking up about the rocker nut or is using poly locks, it will be the rocker that needs adjusting tighter often. I don't think you'll have a problem with stock springs and cam but just be aware.
To Upgrade Rocker Arm
Old Mar 16, 2016 | 10:03 AM
SWCDuke's Avatar
SWCDuke
Someone took an early revision the original paper written by John Hinckely and me and edited it without permission. The latest revision is attached below.
An important issue to understand is that no shaft mounted or ball and socket rocker arm will have a constant ratio. The 1.37:1 ratio is at the lash point and I used this value to develop more refined lash recommendations for mechanical lifter cams where the height of the clearance ramp can be measured or analyzed from the engineering drawing lobe lift data.
The maximum OE rocker ratio is about 1.44:1 with about a 0.3" lobe height.
Whatever the advertised rocker ratio, it's not constant, so you have to take it with a grain of salt and do your own measurements.
Duke
File Type: pdf
Old Mar 16, 2016 | 01:02 PM
pauldana's Avatar
pauldana
I run full RR's under stock valve covers... what I do is run a 1/2" aluminum space between the valve cover and heads... you can get the spacers an eBay very reasonably...
Old Mar 16, 2016 | 06:08 PM
resdoggie's Avatar
resdoggie
Royal Canadian Navy
I wouldn't buy new ones.
