Big Block Valve Cover Question
Old Feb 18, 2016 | 10:33 AM
Pikeslayer's Avatar
Pikeslayer
Default Big Block Valve Cover Question
Does anybody know if the regular BB valve covers will hit the brake booster? Do I have to use the valve covers with the relief angle on them?
Thanks in advance.
Old Feb 18, 2016 | 11:15 AM
CanadaGrant's Avatar
CanadaGrant
I have the stock type chrome valve covers with no relief or slant on the rear and they fit no problem. 69 427. They don't even come close to the booster.
Old Feb 18, 2016 | 11:20 AM
DABall's Avatar
DABall
I have 70 454 and the stock valve covers do have a cut out for the brake booster on the drivers side.
Old Feb 18, 2016 | 11:46 AM
Doug Kraft's Avatar
Doug Kraft
I have tall after market valve covers with no relief area and they fit just fine.
Old Feb 18, 2016 | 12:06 PM
Pikeslayer's Avatar
Pikeslayer
Do you think that relief is necessary?
Old Feb 18, 2016 | 12:08 PM
Pikeslayer's Avatar
Pikeslayer
What year and engine is your vette?
Old Feb 18, 2016 | 03:03 PM
Danish Shark's Avatar
Danish Shark
I think the relief is there to make it easier to remove the valve cover.
Old Feb 18, 2016 | 04:22 PM
CanadaGrant
No. Below is a pic of my 69 427. There is over an inch of clearance all around and they have no slant or relief.
Old Feb 18, 2016 | 10:02 PM
Kim72's Avatar
Kim72
Like others stated. I'm running tall covers with no relief. No problem getting them on and off.
Old Feb 18, 2016 | 10:23 PM
Mooser's Avatar
Mooser
The relief is farther back than you might think
Still pretty tight to the cover but not where that relief really helps.
I often wonder if it wasn't a design carry over from the C2 where the booster was flatter and larger diameter or something and there was more of an issue
M
Old Feb 20, 2016 | 12:37 AM
Doug Kraft's Avatar
Doug Kraft
1976. We put a big block in it back in 1982.
Old Feb 20, 2016 | 03:21 AM
roscobbc's Avatar
roscobbc
Can't comment about valve cover/PB clearance - mine is BB with Brodix heads and their tall cast valve covers - I did need to 'relieve' corner of firewall/bulkhead close to corner of brake mounting point as covers were hitting body due to torque reaction with engine.
Old Feb 25, 2016 | 11:23 AM
Pikeslayer's Avatar
Pikeslayer
Thanks for the responses guys. I'll run the covers I got with no relief.
To Big Block Valve Cover Question
