I'm working on a '78 for my father in-law. We put a crate motor in it recently. I just got the engine to the point of starting. I was going to bump the starter to get to TDC on #1 cylinder to set the timing. Nothing happens when I turn the key. No click. Nothing. The starter is wired correctly and I have a new hot battery.
I did a lot of searches here and learned a bunch about this type of problem. It seems as though the starter interrupt relay could be the problem. My question is can I bypass this relay or simply disconnect it to get the starter to crank? Your thoughts and input please.
More information - the car has a manual transmission and I have been trying to start it in neutral.
This is a schematic of that circuit I think. Wish I could help further. You would need to bypass the purple wire, but IDK where the anti-theft relay is in the car.
it could possibly be the neutral safety switch, which on a manual car is mounted on the clutch pedal under the dash i believe. you can jumper it out or it may just need adjusting. should have a purple and yellow wire...just an idea... dont believe there were any factory starter interrupt relays for the alarm system in 78
Clutch safety switch. Clutch pedal must be pushed to the floor even if the trans is in neutral to engage the starter. The switch is off a rod connected to the clutch pedal arm under the dash and as said above, you can bypass it if it's faulty by jumping the two wire connector that it plugs in to. It has nothing to do with the clutch itself or clutch adjustment. It's just the position of the clutch pedal arm under the dash that operates the switch.
