Fixing little issues
Old Feb 22, 2016 | 04:36 PM
Capt Ken's Avatar
Capt Ken
Default Fixing little issues
Discovered yesterday that the radio will not work in the Acessory position. PO probably miss wired it. Which wire at the steering column connector supplies power in the ACC position. Did a search but didn't come up with an answer.
Old Feb 22, 2016 | 05:10 PM
oldboat's Avatar
oldboat
if the radio works in the run position it is wired correctly. if it then doesn't run in the accessory position the switch on top of the column under the dash needs to be adjusted.
Old Feb 22, 2016 | 05:40 PM
Capt Ken's Avatar
Capt Ken
Default Thanks
Can you be a bit more specific about the switch that needs to be adjusted. Been a while since I was working down there, don't remember any switches.
Old Feb 23, 2016 | 08:45 AM
Capt Ken's Avatar
Capt Ken
Default re
After some thought, IIRC the ignition switch tumbler actuates a sliding switch via a push rod. Is this what needs adjusting?
Old Feb 24, 2016 | 02:00 PM
GUSTO14's Avatar
GUSTO14
The ignition switch is attached to the top of the column (just above the toe of your foot) with 3 small sheet metal screws. Here you can see that the holes are slotted to allow the switch to be synchronized with the key position.
It is not uncommon for the screws to get a little loose over time and allow the switch to move out of the sync'd position and cause the problem you're having.
I believe that the screw heads are 1/4". A small ratchet and socket or box wrench is all you need to adjust it.
Good luck... GUSTO
Old Feb 26, 2016 | 09:24 AM
Capt Ken's Avatar
Capt Ken
Default Re
Took a couple tries to find the right position but got it fixed. Had to loosen the bolts and drop the steering column a little. No room for a socket, wrench only. On mine it was 5/16.
To Fixing little issues
