Rear axle slop
Old Feb 22, 2016 | 10:39 PM
grancuda's Avatar
grancuda
Default Rear axle slop
I am assuming this isn't normal slack but once the weight of the car is on it maybe it's fine. There is virtually no play from the 3 to 9 o'clock position. The car drives good and every now and then I get a noise from the rear end occasionally and just trying to figure out where the noise it coming from.
Old Feb 22, 2016 | 10:47 PM
mortgageguy's Avatar
mortgageguy
I'm gonna say wheel bearing.
Old Feb 22, 2016 | 10:58 PM
grancuda's Avatar
grancuda
Not the wheel bearing, the whole trailing arm assy is moving.
Old Feb 23, 2016 | 01:07 AM
cagotzmann's Avatar
cagotzmann
You most likely have 3 problems
1 side yokes in diff are worn
2 wheel bearings are out of spec
3 trailing arm bushing are worn
For the first 2 you need to remove the half shaft to measure end play
To fix the side yokes you will need to remove the diff
To fix the bearings you will need to remove the trailing arm ( some leave the ta in place)
Once the trailing arm is removed you can check the bushing
Expect the worse and hope for the best
Old Feb 23, 2016 | 07:11 AM
newbie2vette's Avatar
newbie2vette
The second Vid shows more movement from the half shaft flange, taking the half shaft out is easy enough to verify. While the shaft is out, you can verify the spindle bearings.
On the positive note: It's not that hard to rebuild the trailing arms.
Old Feb 23, 2016 | 08:30 AM
speedreed8's Avatar
speedreed8
3rd video looks like there's some slack in your u joint also.
Old Feb 23, 2016 | 08:48 AM
GUSTO14's Avatar
GUSTO14
I agree that the second and third videos seem to be showing some slop in the outer U-joints of the half shafts. If the outer joints are worn, it stands to reason that the inner joints are loose as well.
All the videos seem to show the half-shafts/side yokes are moving in and out of the differential more than they should. As mentioned, you'll need to disconnect the half shafts from the spindle to determine just how much of the movement is in the side yoke and how much is in the U-joints. Don't be surprised if you can pull one (or both) half-shaft & side yoke from the differential.
Depending on what you discover, the solution can become challenging.
Good luck... GUSTO
Old Feb 23, 2016 | 09:04 PM
grancuda's Avatar
grancuda
The stub axles out of the rear housing have 0.11 & 0.09 in/out movement in / out. I am going to replace the 4 u-joints & look up what the spec is on the stub axle movement.
Old Feb 23, 2016 | 09:17 PM
cagotzmann's Avatar
cagotzmann
I would like to see 0.010 max when replaced with new yokes, and many look at 0.025 - 0.050 max. anything more than this the c-clip is ready to fall off and then there will be nothing holding the side yoke in the diff.
With the amount you measured it is time to open the diff and have a look, but you will need to replace the side yokes. You may also have posi clutch wear, but until a new yoke is installed and measured again it is impossible to tell.
Did you also check the end play of the wheel bearings ?. With the side yoke removed this is the best time to check them.
Old Feb 23, 2016 | 09:19 PM
grancuda's Avatar
grancuda
I will pull the shafts off the wheel bearings & check them to see what they are at.
Also, my car is a '69 & one of the half shafts are marked like a salvage as '74 Corvette. Are '69 & '74 shafts the same?
Also, when looking at pics online it seems mine has adjustable bars for camber & the stocks ones are not adjustable.
Old Feb 23, 2016 | 09:35 PM
GUSTO14's Avatar
GUSTO14
The original ones are adjustable at the bracket mounted to the bottom of the differential with an eccentric bolt.
photo courtesy Paragon Corvette Reproductions
https://www.paragoncorvette.com/p-35...-bolt-kit.aspx
Good luck... GUSTO
Old Feb 23, 2016 | 11:28 PM
grancuda's Avatar
grancuda
Good luck... GUSTO
Yes, the cam bolts are the adjustment for the stock bars that are solid but someone added some threaded bars to adjust even more. Not sure why, maybe easier to make changes on the fly.
To Rear axle slop
