You'll need to disconnect the current power supply wire to the lighter, and terminate it propwrly--remmeber, this wire is ALWAYS live, so safety is key to prevent any inadvertent shorts or power flow.......
Run a new (appropriate gauge) supply wire from the "IGN" spade on your fuse box...This is a full 12Volts, and only supplies power when the key is in the "on" position.
Or, you can just unplug the three power adapter each time...
Was just out in the garage with the meter checking stuff. I must be getting old, as i already have used the IGN spade for a different project in the past.
