Engine died and won't start now
Old Feb 27, 2016 | 09:55 PM
68Thunder427's Avatar
68Thunder427
Default Engine died and won't start now
I went out and started my 68 went to grab a drink and all of a sudden the engine just stopped. Hopped back in to start it and it turns over but won't start. Currently have HEI distributor installed and have 12 volts to the power wire on distro. Where or what should I check next?
Old Feb 27, 2016 | 10:10 PM
havesometo's Avatar
havesometo
Look down the carburetor and see if it's getting gas
Old Feb 27, 2016 | 10:51 PM
rcread's Avatar
rcread
Check for spark. Check for fuel.
Old Feb 28, 2016 | 09:56 AM
68Thunder427
Getting fuel but no spark. Measure 12 volts to ignition module then on outlet side of module it measure 1.37 and .40 cranking. Have 12 volts to the coil but only getting 1.37 out of coil cranking. Guessing it is a bad coil.
Old Feb 28, 2016 | 12:35 PM
speedreed8's Avatar
speedreed8
ignition module.
Old Feb 28, 2016 | 02:08 PM
EIGHTY's Avatar
EIGHTY
Originally Posted by speedreed8
ignition module.
Been through this before twice. Order a new ignition control module or even pick one up from a local parts store. It takes 10 minutes to switch out the bad one.
Old Feb 28, 2016 | 06:58 PM
Duane4238's Avatar
Duane4238
And make sure you follow the directions that come with the module for installation. You have to put dielectric grease on the bottom of the module or it won't last long. Found that out years ago on my son's Cavalier. Good luck.
Duane
Old Feb 29, 2016 | 01:32 PM
SH-60B's Avatar
SH-60B
Duane
Dielectric grease to better transfer heat from module to distributor body.
Old Feb 29, 2016 | 09:14 PM
drwet's Avatar
drwet
Agree. Module.
Old Feb 29, 2016 | 09:41 PM
jlaw68's Avatar
jlaw68
I had a one of the 2 wires for the coil under the cover on top of the distributor leave me stranded once before. Worth a look.
Old Mar 1, 2016 | 05:06 PM
68Thunder427
I went to throw the top back on and roll up the windows and for the hell of it bumped it over and it started. Let in warm up and when I revved it a little it dies again. Figured once the module got hot it was cutting out. Well replaced the module and still won't start. I hate electrical just because of this. ANY ideas here guys?????
To Engine died and won't start now
