Need help with H-pipe install
Old Sep 2, 2002 | 02:25 PM
PRNDL's Avatar
PRNDL
Default Need help with H-pipe install
I have an H-pipe kit from Summit. They call it a balance tube. It is just two T-type fittings with a pipe that connects them. The T-type fittings get spliced into your exhaust pipes. One problem is I need a straight length of pipe about a foot long to splice the T's into, and the only place I can find one foot of straight pipe is about halfway back on the rear pipes. I would prefer to put the balance tube in the front pipes, but they bend too much. Any thoughts or ideas? Might be easier to have a muffler shop do it. MJ
Old Sep 2, 2002 | 02:58 PM
73454's Avatar
73454
Default Re: Need help with H-pipe install (MNJack)
Hi Jack,
I don't have the equipment to deal with exhaust pipes either so I always take it to the shop. Are your existing exhaust pipes in good shape? The shop could easily install an H-pipe in to the stock set up.
Everyone seems to put it just after the X-member but I am unfamiliar with your set up. The closer to the X-member the better I suppose.
Good Luck
Old Sep 2, 2002 | 03:15 PM
Brettmc's Avatar
Brettmc
Guys correct me if I'm wrong but I saw a sidebar in Super Chevy or Chevy HiPerformance about placement of h-pipes. What they did was spray paint a stripe doen the pipes and take the car for a run. After that, they looked at the paint stripe and placed the h-pipe at the point where the spray paint was bubbled. I guess the reasoning was to place the h-pipe at the hottest point in the exhaust pipe . Now as to why I don't know, they didn't say.
Old Sep 2, 2002 | 08:23 PM
GTR1999's Avatar
GTR1999
Hi Mark.
I have the same kit from Summit, it's sitting in a pile with all the other things I have to sell some day. There was no room to install these on my car plus I'm running chambered pipes too.
I had a good muffler shop fab the offset pipes to connect my headers and install a 2" H pipe right behind the bellhousing.
Gary
Old Sep 2, 2002 | 10:39 PM
gdh's Avatar
gdh
I'd send them back to Summit, go to good exhaust shop and due what Brett had suggested. If you're running 2.5" tubes a 2" H-pipe will suffice.
[Modified by gdh, 9:40 PM 9/2/2002]
Old Sep 3, 2002 | 02:18 AM
PRNDL's Avatar
PRNDL
Default Re: Need help with H-pipe install (gdh)
good advice! Thanks, I do appreciate it, but I am too dumb to follow advice... I will go to the local Midas and ask them what they can do and how much it would cost, but i have an extra set of rear pipes and I will probably chop them up and try to install the balance tube to see if it changes anything. :) MJ
Old Sep 3, 2002 | 02:55 AM
8T1-7T9 BIONIC VETTE's Avatar
gdh,
This what they did to mine....I have 2 1/2" pipes and they installed 2" cross piece just after the trans crossmember......works great. :seeya Cappy
Old Sep 3, 2002 | 04:50 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Mark, if and when you got to that point, how were you going to attach the pipes together? Are you holding out on us? Do you have a torch to weld the pieces together? :confused:
Old Sep 3, 2002 | 09:24 AM
vettfixr's Avatar
vettfixr
Here's a recent post of mine that shows how the H pipe was hooked up.
http://forums.corvetteforum.com/zerothread?id=374638
Old Sep 3, 2002 | 12:35 PM
PRNDL's Avatar
PRNDL
Default Re: Need help with H-pipe install (vettfixr)
nice pic, vettfixr! :) When I put my headers in I will get a chance to put an H-pipe accross the front pipes. The gizmo I have now would clamp on - 3 clamps on each T - no welding. The entire exhaust system including the mufflers (and elbows) is clamped right now. Holding together pretty well so far. MJ
To Need help with H-pipe install
