L89 intake gasket question
Old Feb 28, 2016 | 12:27 PM
tfringo's Avatar
tfringo
Default L89 intake gasket question
Did 68 L 89 use block off plate gaskets in the heat passages.
2nd question. If they didn't use them, is it better to use the block of plates.
So which is the better configuration. Any info and GM part numbers appreciated. Thanks
Old Feb 28, 2016 | 09:24 PM
PAmotorman's Avatar
PAmotorman
you can not use the heat riser cross over plates if you want to have a operating choke. only the L88 had a inoperable choke. you will make more power with the cross over blocked to keep the heat from the intake manifold.
Old Feb 28, 2016 | 09:29 PM
Sayfoo's Avatar
Sayfoo
[QUOTE=PAmotorman;1591661226]you can not use the heat riser cross over plates if you want to have a operating choke.
I read the hype a few years ago and blocked off my manifold. Big mistake! The car took for ever to warm up and run right, even in SoCal. I changed it back about a month later.
Old Feb 28, 2016 | 09:45 PM
PAmotorman's Avatar
PAmotorman
[QUOTE=Sayfoo;1591661277]
I ran all my aluminum intake hi per engines with the cross over blocked and I live here in Pa. cast iron intake is a different matter as it will not heat up
Old Feb 28, 2016 | 10:46 PM
tfringo's Avatar
tfringo
Default So,
So, aluminum heads and aluminum intake and operable choke needs to have open cross over.
I have take engines apart with them in there and I seem to recall the choke as operable.
Question again.... Some gasket kits seem to not completely block off the passages, they use a stainless restrictor plate that has a small opening in it. Is this considered blocked off??
[QUOTE=PAmotorman;1591661389]
Old Feb 28, 2016 | 11:28 PM
Solid LT1's Avatar
Solid LT1
My wife's 70 LT-1 has factory carb/choke with blocked off Xover passage, I think the heat conductivity of an aluminum intake allows you to do this.
Old Feb 29, 2016 | 12:00 AM
ddawson's Avatar
ddawson
If you want to block it install the metal block. Otherwise leave it out.
I have an electric choke so its blocked. Works great for me.
Old Feb 29, 2016 | 07:29 AM
tfringo's Avatar
tfringo
I'm just trying to get this right without taking this engine back apart. I seem to recall tri powers wanting to boil the gas out of the carburetors. Granted, this could have many causes. My engine will essentially be stock.
So question again: Are there three options; no block off plate; block-off plate with a hole in it and a complete block off plate with no hole in it? Makes me wonder. I appreciate the comments from the board. Thanks everyone!
Old Feb 29, 2016 | 08:48 AM
PAmotorman's Avatar
PAmotorman
just use .005 thick stainless steel shim stock to block the crossover. bend a 90 degree tab at the top if you don't like the way it runs just drain down the coolant and loosen the intake bolts and pull out the shim stock. you have to use SS or it will burn thru. I installed dozens of block offs this way just by draining down the coolant and cracking loose the intake bolts.
To L89 intake gasket question
