Twitchy handling.
Old Mar 1, 2016 | 01:16 PM
Jimmy76's Avatar
Jimmy76
Cruising
Default Twitchy handling.
My 76 has had every suspension component replaced. A good 4 wheel alignment was done. And yet, the car feels very light in the front end. More like Cadillac steering as opposed to a Corvette. Any small input to the steering wheel makes the car feel nearly out of control at highway speeds. It wants to wander. Going into a corner hot makes it feel like the rear end want to break loose.
The only thing not replaced are the rear cross member bushings. Any ideas? I'm stumped.
Old Mar 1, 2016 | 01:22 PM
Kacyc3's Avatar
Kacyc3
Just because it has all new parts and alignment does not mean the car has optimal specs. Did they give you a print out of the alignment?
Old Mar 1, 2016 | 01:26 PM
bruiser's Avatar
bruiser
St. Jude Donor '15
Mine was scary on the highway until I increased the toe in on the back wheels.
Old Mar 1, 2016 | 01:27 PM
SH-60B's Avatar
SH-60B
More caster would stabilize the steering. Please post the alignment results.
Old Mar 1, 2016 | 01:59 PM
Jimmy76's Avatar
Jimmy76
Cruising
Unfortunately, I didn't get the alignment results printout. I think the guy was completely frustrated by the car. He said he spent eight hours working on the car. Get one thing right and something else was wrong.
Bruiser, can you suggest (about) how much toe in you added?
SH-60B, More caster front or rear? How much to start?
It almost sounds like I'm gonna have to spend the day with the alignment guy and do the old test-and-tune on the car.
Old Mar 1, 2016 | 02:06 PM
Jimmy76's Avatar
Jimmy76
Cruising
I have called the shop to see if the alignment print out is available. The job was done last summer. Fingers crossed.
Old Mar 1, 2016 | 02:32 PM
MelWff's Avatar
MelWff
click on download on this link and tell the shop to follow the specs
https://www.vbandp.com/index.php?opt...=43&Itemid=131
what is your cold tire pressure?
Old Mar 1, 2016 | 02:43 PM
hugie82's Avatar
hugie82
Mine didn't get like that until the rear trailing arm bushings started to go bad. I know you said everything was replaced but are they shimmed and tightened correctly. Any movement will be magnified 10x at highway speed. Especially on a wet road.
Old Mar 1, 2016 | 02:46 PM
Jimmy76's Avatar
Jimmy76
Cruising
Running Firestone P235-60R-15. 32 psi all around.
Thanks for the spec sheet. I'll compare it to the results when I get them from the shop.
Old Mar 1, 2016 | 02:49 PM
Jimmy76's Avatar
Jimmy76
Cruising
Vette Brake rebuilt the t arms. I have to assume the bolts were tightened correctly when the alignment was done. The handling didn't improve much at all after the alignment.
Old Mar 1, 2016 | 03:12 PM
C3Bob76's Avatar
C3Bob76
I had the same experience in my '76. Everything was rebuilt, alignment in spec, and it still was very twitchy up front. I eventually replaced the factory power steering for a Borgeson setup, big improvement in road feel. The factory setup was notoriously twitchy, even properly adjusted. Not saying you should rush out and get one, but I'd keep it in mind.
Old Mar 1, 2016 | 03:29 PM
Jimmy76's Avatar
Jimmy76
Cruising
Hey, any port in a storm! The car is nearly unsafe on the highway. My wife won't drive it (not that that's a bad thing). I'll do some research on the Borgeson system. I had an '80 that was firm and true on the road. Comparing the two is like apples and oranges. That car went where you pointed it. The 76 seems to have a mind of its own.
Old Mar 1, 2016 | 04:02 PM
MelWff's Avatar
MelWff
check the condition of the steering shaft rag joint and read this article on adjusting the play in the steering box
http://jimshea.corvettefaq.com/?p=810
Old Mar 1, 2016 | 04:07 PM
Kacyc3's Avatar
Kacyc3
If I remember correctly there is toe and camber adjustment for the rear. Take the specs from the link listed above and have them adjust to that, I had mine done to some similar to that and its alot better than it was. I am still looking at aftermarket upper control arms to get it right. If I can find mine sheet when I get home ill post it.
Old Mar 1, 2016 | 04:16 PM
454Luvr's Avatar
454Luvr
I strongly disagree that these cars are twitchy from the factory. Aftermarket steering is not required in order to solve your problem. My '72 and '73 could both be driven at speeds in excess of 120 MPH with no instability whatsoever. Something in your chassis or steering is worn or broken, or the alignment is way off. Are you saying the alignment guy spent eight hours on the car? Something is seriously wrong, either him or the car. I'll just add that the only time I ever had a Vette do something like this, it was an early C2 with worn out ball joints.
Old Mar 1, 2016 | 04:17 PM
REELAV8R's Avatar
REELAV8R
My 77 had what I would call overly sensitive steering until I rebuilt the power steering control valve and was difficult to control or at least took considerable concentration at speed.
Inside the steering control valve is a piston inside of a piston with a spring that is supposed to dampen the hydraulic pressure spikes from the pump as you turn the steering. At least this is the conclusion I came to after rebuilding the control valve. It may or may not be true. However the change in the sensitivity of my steering before and after leads me to believe that it is.
I discovered that the small piston with the spring inside the larger piston seized to the inside of the larger piston. Once I freed it up and rebuilt the power steering then it was normal or what I would call normal for power steering.
Is your power steering super easy, like one finger with little effort while stationary, easy to turn? If so this could be your issue or part of it in any case.
Old Mar 1, 2016 | 05:18 PM
Jimmy76's Avatar
Jimmy76
Cruising
One-finger steering is very true. That's why I used the Cadillac comparison...way too easy for a sports car.
I have the kit to rebuild the P/S control valve as well as the pump and slave cylinder.
To Twitchy handling.
Old Mar 1, 2016 | 05:20 PM
Jimmy76's Avatar
Jimmy76
Cruising
Wow. 120 MPH would be a death wish in my car! I considered the ball joints but they were replaced about 5K miles ago. I have inspected them, greased and inspected them. They look Ok. I wondered about the eight hour alignment. Especially after there was no significant improvement post-alignment.
Old Mar 1, 2016 | 05:22 PM
Jimmy76's Avatar
Jimmy76
Cruising
There is certainly adjustment to the camber/caster in the rear. After I get some other things finished, it's back to the shop I go.
Old Mar 1, 2016 | 05:27 PM
Jimmy76's Avatar
Jimmy76
Cruising
I've inspected but not replaced the rag joint. It "seems" solid (no lost motion). I wondered about the steering box. The car has well over 120K miles since new. I'd like to rebuild the steering box. Now may be the right time.
Thanks!
