Easy octane question
Old Sep 3, 2002 | 01:34 AM
jonny4523's Avatar
jonny4523
St. Jude Donor '05-'08
Default Easy octane question
which one? stock '77 L48. I have been putting midgrade. Should it take prememium instead?
Old Sep 3, 2002 | 01:44 AM
Stevo81's Avatar
Stevo81
Default Re: Easy octane question (jonny4523)
Buy it and try it? If you notice a difference and don't mind the increased cash outflow...do you race?
Old Sep 3, 2002 | 01:48 AM
73454's Avatar
73454
Your stock compression ratio is below 9.1:1 so anything other than good 'ol regular would be overkill.
I run regular in my 454 with no troubles at all. I did drop the timing though.
Enjoy!
Old Sep 3, 2002 | 01:56 AM
Lohkay's Avatar
Lohkay
Default Re: Easy octane question (73454)
Enjoy!
yup...regular will do
Old Sep 3, 2002 | 02:13 AM
L48Shark's Avatar
L48Shark
From: If you can read this, thank a teacher. If it is in English, thank a veteran.
Cruise-In IV Veteran
Cruise-In V Veteran
When I bought my '77 L-48, I always used 93 octane. (I think the owner's manual says something about using premium gas.) When this became too expensive as fuel costs rose a few years ago, I switched to 87 octane and never noticed the difference.
Old Sep 3, 2002 | 04:46 AM
sped01's Avatar
sped01
regular is always fine unless u get a knock then u would want to switch to a higher octane
Old Sep 3, 2002 | 05:38 PM
Larry B.'s Avatar
Larry B.
Default Re: Easy octane question (sped01)
Regular is for lawn mowers... I have used amoco 93 in our 3.1 minivan for 178,000 mile, NEVER touched the injectors or use even ONE can of any kind of treatment. I can't say that about friends who use Cheap regular in their cars.
[Modified by silvervetteman, 4:38 PM 9/3/2002]
To Easy octane question
