timing tip
Old Mar 8, 2016 | 06:12 PM
ronarndt's Avatar
ronarndt
Default timing tip
Don't know why I didn't think of this years ago for setting timing on cars with vacuum advance on the distributor. Usually, I would disconnect the vacuum line and plug it with something- usually a golf tee- and reconnect it- unless I forgot- when finished. For years I have had an assortment of surgical instruments used in my real job in my tool box for delicate work on electronics or in tight quarters. It never dawned on me to just clamp off the vacuum line with a hemostat to do the timing and then remove it when done. DUH. I just have to remember it gets hot (burned fingers) if left on for any more than a couple minutes. There are lots of similar clamps available that will work just as well.
Old Mar 8, 2016 | 06:21 PM
toobroketoretire's Avatar
toobroketoretire
A little piece of paper will also work once the engine is started
Old Mar 10, 2016 | 10:34 AM
gungatim's Avatar
gungatim
I usually just stick the hose on an exposed valve cover stud or a pin on the carb, the air filter stud, or whatever is handy...but that is a good trick if you have them. they do also actually sell a set of those for hoses, brakes/heater/vacuum, etc. I think even HF sells a cheapo set...
Old Mar 10, 2016 | 10:42 AM
jim2527's Avatar
jim2527
Whats your 'real job'? Make sure its clamped before the engine is started.
I have a few surgical instruments as well..
Jim<cardiovascular perfusionist
Old Mar 10, 2016 | 10:48 AM
COOLTED's Avatar
COOLTED
I have some surgical tools as well, got them after I stabbed my knee with a chisel.
Old Mar 10, 2016 | 01:30 PM
gungatim's Avatar
gungatim
next time you have a disagreement with your knee, try and reason with it and work things out peacefully...violence is never the answer
Old Mar 10, 2016 | 08:11 PM
terry82's Avatar
terry82
maybe you did not use the hempstat clamps before was because you were using them for something else.
Old Mar 10, 2016 | 11:39 PM
ronarndt's Avatar
ronarndt
"because you were using them for something else". Nah- it's hard to open a drawer in my house without finding some type of stainless steel "tool". I had about a half dozen hemostats of various sizes hanging on my peg board in the garage ten feet from the car. I just never thought about clamping the line instead of removing it and plugging it.
Old Mar 11, 2016 | 12:19 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
Are you insinuating clamps are better than burning your fingertips?
Ahhhhhhhhhhhhhhhhhhhhh........memories!
To timing tip
