Installing solid motor mounts
Old Mar 9, 2016 | 11:39 AM
Bloodzone's Avatar
Bloodzone
Default Installing solid motor mounts
After much deliberation I'm installing solid motor mounts with a energy suspension trans mount. My 383 has 470 torque and I've broken 1 set of parts store mounts and I think my second set are on the out as well. I'm hoping for not too much vibration. If I do I'll switch to energy suspension all around. I will post back after install with results. Also hoping for a little more HP to the ground with the less flex. Any guesses on outcome?
Old Mar 9, 2016 | 11:52 AM
gkull's Avatar
gkull
Solid motor mounts are just the natural progression as power goes up. When my stock mounts failed I went to the locking poly Energy S. When they melted and failed i went to Morroso solid.
Old Mar 9, 2016 | 12:11 PM
Garys 68's Avatar
Garys 68
Solid motor mounts with my 6.0 LS swap.
Not much effect with noise or vibration, but then again, I'm running sidepipes.
Not sure if any effect on my convertibles frame flexing. Thinking a spreader bar might help with that.
Old Mar 9, 2016 | 12:18 PM
Bloodzone's Avatar
Bloodzone
Cool, I already have spreader bar installed
Old Mar 9, 2016 | 01:15 PM
ignatz's Avatar
ignatz
Why is that? These things have always scared me. While they transmit the same torque to the frame welds, any shock transmitted is far quicker. If the bolts through the frame are loose, the motor is going to bang them hard.
Old Mar 9, 2016 | 01:25 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Yeah and if your lug nuts aren't tight your wheels will fall off. Jeese, solid motor mounts are the way to go, been running them for years. Helps with frame flex and I don't notice any vibration over stock motor mounts.
Old Mar 9, 2016 | 01:38 PM
ignatz's Avatar
ignatz
I know, I'm a big baby, but I've had broken motor mounts and the downside is pretty bad.
Old Mar 9, 2016 | 01:53 PM
MotorHead's Avatar
MotorHead
All in fun no criticism intended
Old Mar 9, 2016 | 03:08 PM
OzzyTom's Avatar
OzzyTom
Only a slight noticeable vibration on cold start with my solid mounts.
After a few minutes, there is no discernable increase in vibration from stock mounts.
Now when I blip the throttle, instead of the engine, the whole car torques over!
Old Mar 9, 2016 | 03:34 PM
JoeC427's Avatar
JoeC427
Old Mar 9, 2016 | 07:00 PM
gkull's Avatar
gkull
I've never had the motor side or the frame side come loose. i use things like lock washers and Nylock nuts.
On the other hand wimpy motor mounts scare me. I was driving my vette home at night (fast) on a mountain road........ I floored the gas at the apex of a turn and the steering bound up. I let of the gas and the steering came back. I floored it and the steering bound up again. The ES poly had melted and then broke allowing the header tubes to TQ over into the steering shaft before the box.
Running around a 4.2 mile road racing track my headers get so hot that they glow like on the long straightaway. That is what melted my Energy suspension Red poly locking motor mounts. They were a PITA to remove because the red poly melted over the motor bolts. so I had to grind and chisels the ploy away to get to the bolt heads.
Then days later they broke while driving.
Old Mar 9, 2016 | 07:27 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
I had a left-side solid motor mount develop a 3/4 crack with about 6 months of usage. I'll never go that way again and am sticking to the newer rubber mounts with the safety interlocking feature.
Old Mar 9, 2016 | 07:36 PM
pawpaws toy's Avatar
pawpaws toy
How about using a torque strap?
Old Mar 9, 2016 | 07:48 PM
ignatz's Avatar
ignatz
Thanks for the reply later but I wanted to go back to your original supposition as to why, with a more powerful motor, you said that solid mounts were a "natural progression". I think it is exactly the opposite. And that the problems you later described were with heat and not torque.
I look at the welds on my frame and I think to myself - is that all there is? - wishing when I had the body off I'd beefed it up a lot. My thinking was with an LS376/515, maybe I should go easy on things? Also with an aluminum motor, maybe I don't want it to be part of the frame?
I have previously had my share of motor mount issues, motor torquing over to full throttle in a parking lot, fan slicing a radiator hose. Bought the best mounts I could for this car and then put some additional heat shielding between the manifolds and the mounts. So far so good, nothing has melted.
The downside has been with adapter plates and stock mounts the motor sat high enough that none of the standard hoods would fit. A custom welded up adapter would have fixed that but I really wasn't up to the risk.
Other than the one negative response seems like it's not a big deal and has worked out for most folks.
Old Mar 9, 2016 | 10:34 PM
petronix's Avatar
petronix
I have Moroso solid motor mounts in my 72. It has a ~500HP solid lifter small block. Frame is fully seam welded with Borgeson steering box and big hole for power steering ram welded up. Frame still twists around a bit on bumps and turns. Motor does not move at all watching the air cleaner through an l88 hood. I was more worried about cracking the block than the spaghetti frame.
I had to pull the 4-speed. Those sold mounts are not that solid. The back of the motor still moved up and down several inches to help install and remove the transmission.
I had poly mounts. They were melted after 10k miles with the old l48 and long tube headers. I notice no difference in vibration between the solid and poly mounts even with double the horsepower. I do still have the poly transmission mount. I would not go solid there.
Old Mar 10, 2016 | 12:12 AM
gkull's Avatar
gkull
TQ broke the melted poly
Not all solid mounts are created equally. The older Morroso were thicker metal than their new items.
I have not broken my my thicker morroso with solid with my 5 speed and the TQ of my 434 road racing and drag racing with big slicks
Old Mar 10, 2016 | 02:14 PM
pauldana's Avatar
pauldana
I run these, with a 650hp 427 hitting the track about 10 times a year, and the canyons about another 15 times a year... had them now about 2 years... no problems, and yes, I work my vet very hard.
1 7/8" headers, no melting yet:-)
http://www.summitracing.com/parts/en...make/chevrolet
Brand:Energy Suspension
Manufacturer's Part Number:3-1120R
Part Type:Motor Mounts and Inserts
Product Line:Energy Suspension Motor and Transmission Mount Kits
Summit Racing Part Number:ENS-3-1120R
UPC: 703639277002
Motor Mount Style: Complete mount
Bushing Material: Polyurethane
Bushing Color: Red
Bracket Included: Yes
Bracket Finish: Zinc plated
Transmission Mount Included: Yes
Quantity: Sold as a kit.
Notes: Kit includes early style "short and wide" motor mount that measures 2 5/8 in. between the ears and 1 3/4 in. tall to the center of the through bolt hole and polyurethane mount for automatic transmissions.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
These Energy Suspension performance polyurethane motor and transmission mount kits feature the best of both worlds--they're smooth running for the street and are strong enough for the track. Torque-resistant, yet comparable in strength to solid metal mounts, they'll give you the performance you're looking for.
To Installing solid motor mounts
Old Mar 10, 2016 | 10:43 PM
tektrans's Avatar
tektrans
My understanding is when you put in solid motor mounts you want to use a stock rubber trans mount.
Old Mar 14, 2016 | 06:31 PM
Bloodzone's Avatar
Bloodzone
UPDATE: I just got car back home. Engine is very steady no shaking like before. Car seems overall more stable and tight. 700r4 shifts smoother at low speeds. Only extra vibration I can feel is in my feet/floor. Its very slight, but noticeable. She seems to respond better through the gears but that can be my imagination. I'm very pleased with the results.
Just to recap. I changed from parts store rubber motor and trans mount to solid motor and energy suspension trans mount.
Old Mar 14, 2016 | 07:14 PM
wzschirnt's Avatar
wzschirnt
Hi, Glad you got it figured out!
Just FYI - I drag raced the yellow 74 (in my pic) for over 10 years with just a solid left mount (that's what takes all the abuse on a launch) and a stock right motor mount and stock trans mount. No breakage, no problems.
Anyway, have fun!!
walt z.
