So in an attempt to troubleshoot a "jumpy" amp gauge, I disconnected the negative battery isolation switch with the engine running. Reconnected and thought that may not have been a good idea.
The engine didn't stall and I'm wondering if that can potentially fry something? Did I do something stupid to my alternator by doing that or is it no big deal? Car runs OK.
When you disconnected the battery with your engine running the alternator kept it running. No big deal.
"Disconnected the NEGATIVE battery isolation switch" not the positive. We all take off the positive to check alternator working or not. I have no clue if the method original poster used would adversely effect anything. Mark
The battery can absorb power spikes from the alternator that damages electronics. We don't have electronics in our cars, save for the ignition module and the alternator itself, and the radio.
That didn't help with the negative disconnected. Its very random and when it takes a large move it even drags down the idle. Other times it just sits at zero rock solid on the amp gauge. I have a volt meter on the cig lighter and the voltage jumps around from 14.2 to 14.6 volts at idle.
I think I'm chasing a random short....
So in my effort to resolve a "jumpy" ammeter, I found the problem. I replaced the connector in the top of the alternator, soldered the connections at the splices and used shrink tubes to cover. Even though it originally felt tight in the connection, it wasn't. This caused the ammeter to fritz out every now and then and my voltage was all over the place. Problem solved.
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
It's not a wise thing to do. If the alternator happens to be putting out a decent amount of amperage charging the battery, and you open up the battery line, the alternator doesn't have the ability to ramp down the output current instantaneously. You end up with a big inductive voltage spike on all the harness 12v lines. This is a bit abusive on any electronics in the car. Thankfully our antiques have a minimal amount of sensitive electronics content in them. The electronics are designed to deal with this abuse, but there's no up side to pushing one's luck.
I would also worry about frying the bridge in the alternator.
As for positive or negative battery pole, there is no difference, once either of the poles are disconnected no current runs to or from the battery.
The only reason why it is generally recommended to disconnect the negative is that if you short the wrench you use to loosen the connector to the metal body in the car (not an issue in the Corvette) then nothing happens if it's the negative.
That is quick way to check if your alternator is working.If the car shuts off when you disconnect the battery the alt is bad!
