U Joints Flange
U Joints Flange
On rear half shafts when i goto install bearing cup on the spicer wheel flange, the flange flexes and wont seat on u joint any tricks for this? Already messed up one new u joint don't wanna try for two, tried the vice routine and a massive c clamp (actually a universal ball joint press). I can get each one to slide in and out but for life of me cant get them to press together. Oh its a 76....
It is nearly impossible to perform this feat without purchasing the Companion Flange Support Plate from VoloVette. I tried. Can't do it.
Actually, you've probably already bent the companion flange. Not a crisis as long as you haven't cracked it.
What I ended up doing is bolting my companion flange down to the Support Plate with a piece of coat hanger behind it so it would "flex" back into shape. If the companion flange is not 'open' enough, it will compress the u-joint once you put it together again and get the clip on.
Don't ask me how I know all this...
EricBing (03-12-2016)
