Installed 71-82 short waterpump and notice it comes with a shaft size of 3/4in while my standard pulley is only 5/8. Anyone have luck finding a compatable 3/4"pulley?
The C3 Corvettes all came with 3/4" shaft water pumps and 3/4" pulleys so somewhere along the way a 5/8" shaft passenger car water pump and pulley got installed on your C3. You can drill your pulley to 3/4" or buy the correct pulley from one of the vendors.
I read several places they had 5/8 until 1972 and switched to 3/4 in afterward. Are you certain ? It is also 3/16" wider from the block to the pulley than the stock short pump I had
Short-Style Pump for most 1955-72 cars & trucks (5/8" pilot shaft)
- Fits all 1955-68 S/B Chevy passenger cars, 1969-70 350 c.i.d. Corvettes and 1955-72 light duty trucks.
- Has 3/4" ball/ball bearing.
- Dimension from block surface to hub: 5-5/8". Inlet diameter: 1.80".
Long-Style Pump for 1969-87 V8, 90° V6 & 1973-86 truck (5/8" pilot shaft)
- Fits all 1969-87 S/B Chevy or 90° V6 passenger cars and 1973-86 light duty trucks. Does not fit Corvettes (use #8810 or #8812) or
late-model vehicles with serpentine accessory drive belts (use #8881).
- Has heavy-duty 3/4" ball/roller bearing.
- Dimension from block surface to hub: 6-15/16". Inlet diameter: 1.80".
Short-Style Pump for 1971-82 Corvettes 3/4" pilot shaft)
- Fits all 1971-82 S/B Corvettes.
- Dimension from block surface to hub: 5-13/16". Inlet diameter: 1.80".
At pws yes mine is 2nd gen corvette with 5 13/16 block to surface, my stock was 5 10/16. 3/16 difference im wondering how anyone else have made these work? Mine is double groove pulley, I found them also, but a stock pulley would sit 3/16 too far forward im thinking and offset belts? I cant be the only to run into this issue but many searches no luck.
I cannot really tell, but it seems like you are attempting to use a newer water pump on an older Corvette? Is that correct? If so, then it might be easier to just buy the correct pump.
no I have the correcr waterpump for a 71-82. Mine is 1980, my pump is installed and water in my system..doubt resoing with pump with 5/8 would be easier.
Perhaps yours has had the vette pulleys replaced with something else, so when trying to use a vette pump and pulley you have alignment issues. All the pulleys must be vette, no miss-match.
As posted, Ebay has stock pulleys. If you are looking, March has an aluminum underdrive pulley set specifically for our C3's.
As posted I see that, I was wondering about the the belt clearance since the pump I have is 3/16 further forward than my original..mindblowing noone has never has same issue.
my engine is a 350 swap ko512tdj that may be part of issue. They are vette pulleys on right now anyone have there measurements? I could compare mine is 5 7/8 diameter 5/8 center shaft and 2 3/4 deep
I'm not at home to check, but I think there are only a few possibilities going on.
If you had a 5/8" shaft pump on there previously, which cannot be a 72-82 corvette specific pump, and everything lined up, then you didn't have corvette pulleys on the rest of your accessories which made it work.
Now that you put the corvette pump on, things are not lining up.
So you have two options. Use the corvette pump and match it with all corvette pulleys OR use a standard water pump and use the standard pulleys.
Correct me if I am missing your issue?
I am not positive but I believe ive got corvette pulleys they have 5/8 shaft hole im told thats standard for corvette? Searches aeem to say corvette pulleys are also 5/8? This is what idk..if the only difference is 3/16 spacing ill shim the pulleys on now out and keep all the pulleys but i dont feel shimming will even be need to space them to match the waterpump sitting forqard 3/16 more. Also my car only takes 3 belts im not sure about yours?
No. That's what we've been trying to help with. A 5/8 shaft hole is a "standard" short water pump, which was also used on 68-70 SBC C3 corvettes along with every other production small block. In 1971 the corvette water pump got weird and was unique ONLY to 71-82 Corvettes with the 3/4" pilot and an odd backspacing.
So, you HAD a standard 5/8" water pump and pulley set. You bought the correct "corvette short" specific water pump that is correct for your year. Now it does not line up because your other pulleys/brackets are designed for a standard short pump.
You have two options that I stated previously. My opinion? It'd be easiest to return the corvette pump and buy a standard short water pump to get you back to where you were in the first place. If you want to keep the new "correct" pump, then you are going to have to replace all of the pulleys.
Thanks I think you told me what I didnt want to hear lol! I was hoping 3/16" wont matter as it is at the shop to get drilled to 3/4" tomorrow. I suppose i may cancel that but i really would like to use this pump somehow other than replacing all the pulleys. Strange every search yields pulleys with 5/8 for vette. This sucks
I thought thats what very deep groove pulleys were for was for that slack pickup I wish I knew if 3/16 was acceptable play..i could even shim the alt to match idk about the rest
