1972 Wipers
Old Mar 13, 2016 | 10:40 PM
franjw's Avatar
franjw
Default 1972 Wipers
I have replaced the wiper motor and now it works when I press the washer to work. I have replaced the ground wire to the starter. But the wipers do not work yet in low or high speed. Am I looking at the switch or is there another relay that I am looking for. Supposedly the relay in the console does not exist in the 1972. Any ideas as to where to look next?
Old Mar 14, 2016 | 05:40 AM
toobroketoretire's Avatar
toobroketoretire
The wiper motor grounds thru the switch so if the switch itself isn't grounded the motor won't run. If you have the switch dangling connect a jumper wire to it and a good ground and try it again.
Old Mar 14, 2016 | 07:16 AM
65GGvert's Avatar
65GGvert
The panel that the switch mounts to has to be grounded for the switch to get ground also. Connect a jumper from a good ground to the panel the switch is on and see if they work now.
Old Mar 14, 2016 | 08:21 AM
sgt kohler's Avatar
sgt kohler
just went through this. make sure the switch is grounded . I ran a jumper from the battery.
Old Mar 14, 2016 | 01:47 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here is everything I have for you on the 1972 wiper system. First you should upload this file:
1969-1972 Corvette Windshield Wiper Motor Tech Help, Wire Schematic With Test
The wiper relay is located here on the 1972 cars.
Here is how you test it:
Wiper relay testing video
Wiper switch testing.
Wiper motor wiring diagram made simple
Wiper Motor testing with some Relay help
Wiper Motor Bench Test 69-72
Old Mar 17, 2016 | 08:11 PM
franjw's Avatar
franjw
Thanks it was the ground and a backwards connector on the switch. Love these old cars with 3 or 4 former owners.
Old Mar 17, 2016 | 08:12 PM
franjw's Avatar
franjw
Old Mar 17, 2016 | 08:13 PM
franjw's Avatar
franjw
To 1972 Wipers
