1977 Has No Power. Sometimes.
Sometimes, not all the time, all my '77 will do when I turn the key forward to turn it over is let out a "chunk" sound. Then, there is no power. Car is completely dead. I come back a couple of hours later and the power is back but the starter "chunks" again and the car is dead.
Sometimes there is no power after a couple of hours and other times the car will actually turn over.
I have replaced the starter, the negative battery cable and the fusible links. Battery and alternator check out fine.
I get 12.6 volts at the starter but I get far less at the alternator. Should I be getting 12.6 volts at the alternator when the ignition is in "run"?
Also, one time after the starter went "chunk", I noticed that there was no power at the starter. ?? I disconnected the starter and checked the battery cable at the starter and it had 12.6 volts. Hooked it back up and the car went "chunk". Another time I did the same thing and the car turned over.
When there is power in the car, the headlights work. However, one time this past weekend I put the car in run (did not attempt to turn it over) and put the head lights on and it killed the power in the car.
I'm thinking the ignition switch might be bad. Thoughts?
I appreciate your insight.
I understand replacing that cable is challenging but it can't be as challenging as trying to actually diagnose what the problem is.
Also, and this goes towards the idea the positive cable is bad, after the starter goes chunk and there's no power, there's no power at the starter. However, when I checked the cable after I removed it there WAS power. So that would mean that my jiggling the cable got it to work, right?
If the positive cable was good, there should always be power to it. That chunk sound would come from a bad starter which I know is not the case.
Thanks for your insight. This has helped me greatly already!
I also tested the resistance on the positive cable in the car and it's ok. Fusible links are fine, negative battery cable is new, ground to the block from the starter is solid.
Here's what really odd - when the positive cable is on the starter, there's no power in the cable at the starter. When I remove the cable from the starter there is power. ??
This tells me there's a short somewhere.
I'm thinking ignition switch. Thoughts?
Also, is the neutral safety switch part of the ignition switch that's at the end of the steering column?
When the starter goes "clunk," how are you measuring power at the starter? I assume you're using a high-impedance voltmeter of some sort. Describe the exact points where you're touching the positive and negative leads of the meter.
This not the way I should test this?
Thanks in advance for your insight!
When there is no power at the starter there IS power at the battery when I test the battery cables inside the car AT the battery.
Why would there be no power on the positive battery cable when it's connected to the started but when I disconnect it there IS power?
Is it not unusual to not have 12 volts at the starter and to have 12 volts on the positive battery cable when it's off the car? That's what's really throwing me.
I'll take the ground off again and try them again. I bolted the new negative battery cable to an exhaust bracket that bolts to a cross member just in front of the differential. Perhaps I should bolt it back where it came from. I'll be darned if that's the culprit but hey, y'never know. I appreciate your insight!
That diagram would help me out too.
Perhaps it's as "simple" as a grounding issue?
Also going to try putting the new negative cable back on the frame where it was originally. Right now it's on cross member in front of the differential. 454Luvr says that might not be the best place for a ground.
Wish me luck! :-)
